Ok everyone with a zo6 we just changed the oil for the first time and wanted to let u know that the dry sump systwm is no harder than a regular oil system
there are 2 oil plugs in the alum case where the oil pan would be the one closest to the oil filter will drain about a qaurt of oil the one to its left is the drain for the resivor about 7 qts. that is it nothing to complicated .
also the fiter is a pf-48 standard filter mobil 1 oil only I hope this helps some one
