1/8 mile time
Old Feb 10, 2006 | 11:21 AM
k-line's Avatar
k-line
Default 1/8 mile time
My 1/8 mile time was R/T-.523_60'-2.084_330-5.423_1/8-8.085_MPH-94.72. Traction was an issue it was very hard to stay hooked up in 1st and 2nd. What should my aproxamite time in the 1/4 mile be? Thanks
Old Feb 10, 2006 | 11:24 AM
fredgpowell's Avatar
fredgpowell
Pretty good time adn should be in the high 12s sounds good. What mods
Old Feb 10, 2006 | 11:28 AM
k-line's Avatar
k-line
Kooks 1 7/8", x-pipe, high flow cats, vortex, and 100 shot.
Old Feb 10, 2006 | 11:32 AM
LS1LT1's Avatar
LS1LT1
This HAD to be on street tires I assume?
Are you in NM or CO by any chance? LOL
Old Feb 10, 2006 | 11:43 AM
k-line's Avatar
k-line
Yes it was on street tires I spun all through 1st and most of 2nd .(wheel hop was scary) I'm going to have to do something to get the power to the ground. I'm sure more drag experience would also help.
Old Feb 10, 2006 | 11:47 AM
k-line's Avatar
k-line
Irwindale, CA
Old Feb 10, 2006 | 12:09 PM
Oleflippy's Avatar
Oleflippy
I'm going to stick my head out here a little and say that your MPH in the 1/4 would be around 117 and close to a 12.0. The is GREAT MPH on the 1/8 for a 2.0 60 ft. You can run high 11's if you get the 60 ft down a bit. That's almost 95 mph in the 1/8!!! Congrats.
Old Feb 10, 2006 | 12:13 PM
Oleflippy's Avatar
Oleflippy
Oh and PS. I'll take a .523 light on a .500 tree all day long. Nice RT too. Has nothing to do with your ET, but a lot of races are won at the tree.
Old Feb 10, 2006 | 05:03 PM
bunk22's Avatar
bunk22
Great times. Happen to know the weather conditions, like the DA?
Old Feb 10, 2006 | 05:04 PM
06C6FVR's Avatar
06C6FVR
Most tracks now do not use the .500 tree anymore, they switched last year to a .000 tree, and it just counts from the time the light is lit.
Daren
Old Feb 10, 2006 | 06:14 PM
Oleflippy's Avatar
Oleflippy
Yeah, that's a new one on me. Normally you have a .400 pro tree or a .500 tree. He posted an RT of .523 so I assumed that he cut a good RT. At my local 1/4 track, a .500 tree is perfect light. Unless they are running a pro tree, a .400 is a prefect light.
Old Feb 10, 2006 | 06:23 PM
sditch's Avatar
sditch
K-Line,
My mods are very simular to yours excluding the headers and I ran a 11.9 on the quarter mile. My 1/8 mile time was alittle better then yours as I hade about a 7.8 I believe but I only had tire spin at launch.
If i could get my 60FT time down from the 2.0 range with these street tires Im sure 11.5 would be possable. You might be spraying of the line which may be gving you alot of traction issues.
-Sean
Old Feb 11, 2006 | 12:24 AM
JELSIS's Avatar
JELSIS
Your 1/4 Mile ET is 12.68 seconds computed from your vehicle 1/8th ET of 8.085 seconds.
Your 1/4 Mile MPH is 117.45 MPH computed from your vehicle 1/8th MPH of 94.72 MPH.
http://www.wallaceracing.com/Calculators.htm
Old Feb 11, 2006 | 12:46 AM
Oleflippy's Avatar
Oleflippy
These cars can run 12.6's stock with a 8.30 1/8 mile. You have to consider the fact that it spun and killed the 1/8 ET. He had a little bit of trouble with the 1/8, but still went 8.0 at 94mph. The hard work is over at that point, you're already going 94mph and you can spray it the rest of the way!
K-Line, there's no doubt in my mind that you would have ran a very low 12 second pass @ around 117 mph.
Old Feb 11, 2006 | 01:01 AM
qwiketz's Avatar
qwiketz
k line, I'll see you at irwindale sometime.
I've seen stock c6's go 88 so he picked up about 6 mph. Not bad.
Old Feb 11, 2006 | 01:06 AM
cerino2000's Avatar
cerino2000
That's more of a low 12 in the 1/4. Damn nice run.
Old Feb 11, 2006 | 12:19 PM
k-line's Avatar
k-line
I want to go to some more street legal drag days but I am concernd about the wheel hop it's just a matter of time till something breaks, if I can't figure out how to stop it. Anyone have any suggestions. I also made 2 other runs but shut it down because of the hop.
To 1/8 mile time
Old Feb 11, 2006 | 05:38 PM
cerino2000's Avatar
cerino2000
Many of us feel your pain. I am kinda waiting for heavy mods till someone comes up with something that will keep if from hopping while stock. Not much point in all that power if you can't put it to the ground.
Old Feb 11, 2006 | 06:22 PM
yell03's Avatar
yell03
After a few quick calcualtions your 1/8 time and mph converts to a 12.29 to 12.45 @ 118.4
If you can knock your 60' time down to a 1.98 you can knock 2/10s off your 1/4 = 12.09 to 12.25
Nail a 1.88 60' and you will be looking at 11.89 to 12.05
The conversion factors are 1/8 et x either 1.52 or 1.54 (can't remember which) and mph time 1.25.
Howard
Old Feb 11, 2006 | 09:08 PM
JELSIS's Avatar
JELSIS
Great 1/8 mile to 1/4 mile Calculator
