Do LS2 engines come w/ hardened pushrods??
Old Feb 13, 2006 | 04:15 PM
GMRULZ's Avatar
GMRULZ
Default Do LS2 engines come w/ hardened pushrods??
Do LS2 engines come w/ hardened pushrods?? Just curious because I know LS1`s were notorious for bending stock non-hardened pushrods from over rev.
Old Feb 14, 2006 | 12:04 AM
SpinMonster's Avatar
SpinMonster
nope, same as the ls1/6
Old Feb 14, 2006 | 06:43 AM
GMRULZ's Avatar
GMRULZ
Guess I better get more order in then...Lol..
Old Feb 14, 2006 | 06:47 AM
midnite902's Avatar
midnite902
Default HP Engine
LPE's motors come with many strengthed parts including a forged crank, better rods and pistons.
Old Feb 14, 2006 | 07:56 AM
hodgeee's Avatar
hodgeee
No they don't and when doing a cam or heads and cam it is recommended to go with adjustable pushrods if you are going to .580 or taller compression.
Old Feb 14, 2006 | 08:09 AM
davidfarmer's Avatar
davidfarmer
aftermarket pushrods are great (I like Smith bros), but you really need to try and avoid mechanical over-revs, or you're likley going to throw a rod through the side of the block, let alone bend a pushrod.
Old Feb 14, 2006 | 12:15 PM
SpinMonster
What?
Old Feb 14, 2006 | 06:21 PM
GMRULZ's Avatar
GMRULZ
Everyone tries to avoid the over rev, but I can`t tell you how many times at the track I have heard ticking LS1`s. All my friends w/ LS1`s bent or even broke their stock pushrods at one time or another.
Old Feb 14, 2006 | 07:15 PM
hodgeee's Avatar
hodgeee
What?
The stock lift levels are like .530 to .550 inches, this is how much the valve springs compress with every revolution of the motor. The stock valve springs maximum safe compression is like .560 inches of compression. So if you are going anything over .560 of compression with the new cam, of course new springs are needed. The stock pushrods are fine, but run into strength issues when getting over .560 of lift also. For every bit extra of lift, it creates more pressure on the pushrods as well as the springs, retainers, hats and what not of the valvetrain.
You don't need adjustable stronger pushrods, just stronger pushrods, adjustables are just so much easier to adjust the valves with. I did a 1.8 rocker swap on a ls1 motor, and the adjustable pushrods made the job a snap.
Old Feb 14, 2006 | 10:24 PM
SpinMonster
Adjustable pushrods are used to check the length of the pushrods needed to get the geometry right up top and not intended to even be run in a motor nor could they be.
I think you mean adjustable rockers. I'm sure it was an oversight/typo on your part.
Take care
Old Feb 15, 2006 | 02:03 AM
hodgeee's Avatar
hodgeee
Take care
Actually no, they have been using adjustable pushrods in motors for years and years, also very common in harley's since they need much more adjustment due to being a air cooled motor. There are a couple of websites that sell the adjustable pushrods also for our vettes. Yes some motors will not fit them, but most will, and have run them for hundreds of thousands of miles in thousands of motors!!!!!!!!!
I am surprized you have never heard of adjustable pushrods?
To Do LS2 engines come w/ hardened pushrods??
