Retained Accessory Power
Old Feb 14, 2006 | 07:26 PM
speedwaywhite's Avatar
speedwaywhite
Default Retained Accessory Power
Installing after market XM in my 05 Coupe, can any one identify what circuits stay on with RAP mode? I found that the window washer pump circuit is hot on "ACC" but can't locate any fuses that stay hot with RAP. Any advice would be appreciated.
Old Feb 14, 2006 | 07:46 PM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
I thought it was just the radio and power windows
Old Feb 15, 2006 | 08:08 PM
speedwaywhite
I don't understand why I can't find the circuit it uses. I have checked out both fuse panels and have not located a circuit that is hot when RAP is in use and not hot when the ignition is off.
To Retained Accessory Power
