Thanks Rich. How about the procedure to learn the tire pressure sensors?
You will need another tool from Bartec to do this. I got one about a year ago from them and they had special pricing for forum members but am not sure today. The magnet like we all used on the C5 doesn't work on the C6.
Bill
Its 80 bucks and reads CAN vehicles. A predator can reset the codes too and has scan and tuning capability. Get it from a vendor that does custom tunes though if you are modded.
About 3 months ago I had some mods done including mild cam and heads. After 400 miles I got the check engine light. Then, about two days of driving, the code cleared up. Does the computer adapt to mods after awhile? Thanks
the ecm/pcm will continue to run the check that it failed, and if it pass that same test for number of times, it will reset the cel without having you doing it. so it doesn't really adapt mods after awhile...it will
actually see more air coming in and out though various sensors right away and add more fuel to stay within factory fuel ratio (it will "adapt" it's lt and st fuel trims over time, due to your mods, but that is a small adjustment)
