air filters (which one)
Old Feb 16, 2006 | 03:31 PM
little burt's Avatar
little burt
Default air filters (which one)
hey guys let me know what you think just got a new c-6 with the auto (paddle shift) polished wheels black on black, really love it my question is i am going to change the air box i have it down to 2 of them they are halltechs newstinger ssm or the blackwing slp which do you think iis the better of the two, i know some people will say go to a bottom feeder like callaway or one of the other cold air induction system, but i do not want to cut an hole in the shroud. let me know what your thoughts are burt. ps i just order flowmasters new catback sytem for the car looks really interesing saw a write up in april issue of corvette enthusiast.
Old Feb 16, 2006 | 03:44 PM
cbrf4i1's Avatar
cbrf4i1
i know someone that has halltech and i didn't like the build & fit quality wasn't what i was looking for (sorry, i know there are tons of cf members that has them) so i went with a K & n instead. gl
Old Feb 16, 2006 | 05:23 PM
ShockerRacing's Avatar
ShockerRacing
This has been argued over and over and people will come in to this post and tell you to just do a search but I hate when people do that. I would say they are all pretty equal as far as gains go, so pick one that you are capable of installing yourself and that fits in your budget. If you can install any of them pick the one that looks the coolest to you! Its your car and they all are going to be better than stock!
Old Feb 16, 2006 | 07:03 PM
timd38's Avatar
timd38
K & N is a safe buy. That's what I bought.
Old Feb 17, 2006 | 03:53 PM
catbert's Avatar
catbert
I got a Halltech, and I'm really impressed with the seat of the pants improvement - I really didn't expect to notice anything. I haven't had it to a dyno yet, but I have a baseline on the car to compare it to when I get to it.
Old Feb 20, 2006 | 09:07 AM
Low Rider's Avatar
Low Rider
The Hurricane comes with it's own shroud so it requires no cutting.
Old Feb 20, 2006 | 08:13 PM
TonyMDC6's Avatar
TonyMDC6
I bought a K&N about 3 weeks ago and noticed an immediate improvement.
Old Feb 20, 2006 | 08:18 PM
Daylon's Avatar
Daylon
Old Feb 21, 2006 | 01:24 AM
Luftwaffe35's Avatar
Luftwaffe35
St. Jude Donor '10
OK. Two questions. Does anyone have pics of the K&N air intake kit installed on a C6? and, Can you really tell the difference of a 10 hp power increase?
Old Feb 21, 2006 | 08:57 AM
xs650's Avatar
xs650
If you really believe, you can feel the improvement from a 0 hp change.
Old Feb 21, 2006 | 09:09 AM
nicky D's Avatar
nicky D
dont get the slp it only works with the hood open and as far as air flow the calloway honker works the best so far
Old Feb 21, 2006 | 09:56 AM
RBYCC's Avatar
RBYCC
With all due respect..."SLP only works with the hood open" is a very silly statement. Configuration of all air filters be they SLP, K&N, Halltech or even the stock box that do not require cutting into the radiator shroud are the same. They sit in the same area and intake the same air.
What do you have on your C6?????
Old Feb 21, 2006 | 10:02 AM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
I selected the Halltech because I did not want to cut the shroud. Can't really address any difference in HP since I already had dynatech headers and corsa sports on the C6.
Old Feb 21, 2006 | 12:07 PM
andreas g.'s Avatar
andreas g.
Default lean codes at idle
Don't be surprized if you set a lean code, left and right banks at idle with different airfilters. Some don't set them some do It just depends on the car.
Old Feb 21, 2006 | 12:12 PM
fredgpowell's Avatar
fredgpowell
Vararam. This is my personal opinion. They are on sale at Corvettes of Houston. people have been getting allot of codes with certain brands. Make sure you ask question to forum member and dont take advice from someone who does not have one.
Old Feb 21, 2006 | 12:19 PM
Rada 1's Avatar
Rada 1
Default The Halltech
I ordered the SLP and installed it, the bridge did not fit very well and I had to force every thing to make it fit. When I went out for a test drive the car had a low speed surge. I took everything back apart and reassembled it.it was no better I called SLP and they were not much help,sooo I worked out a deal with the vender I got it from and they exchanged it for the Halltech, the halltech went on with no problems and the car runs great, (just my experience)
Old Feb 21, 2006 | 04:16 PM
67Roadster's Avatar
67Roadster
Halltech is a simple and effective approach and easy to return to stock if necessary
To air filters (which one)
