I tried to download the instructions, but couldnt. The description said that 'some cutting' is required for the CAI option but NOT the shroud ; can someone tell me exactly how this CAI is installed on the Halltech filter which appears to sit in the engine compartment ? Also, how much is the air filter replacement ? I was just about to buy the Vortex Rammer system when i came across Halltech. Thanks, Dave. 2006 LS2.
I have purchased the Halltech with the CAI. I am in the process of installing it right now. The short is...the CAI replaces the lower shoud. This lower shoud is the plactic surface on the bottom just inside the grill. If you look closely at the grill area of the stock C6, you will find that on each side(left & right) behind the grill there is a vertical plastic surface. On the CAI this vertical plastic surface has a 5" x 6" hole cut out of it, and a wire mess is placed over the back side to form a grill in the hole. It would be very easy to modify the stock lower shoud by cutting these two holes out on both sides.
REPLY: Can u tell me how the cold air is taken to the filter itself ? Do you have to run hoses or how exactly do they accomplish it. ??
i just mod my stock piece, the instruction isn't very clear at all just so you are aware...there is no cold air to the filer, these 2 holes just allow outside cooler air into the engine compartment, which is where the air filter get the air from...i thought about running some hoses up by the filter but i think it will look cheesy...
REPLY: I just went out and had a look at my 2006. On each side of the front grille just inside, i see a black plastic housing that is solid. You can see the back part of it from the engine side way down in each corner -- if they were cut open , cold air would blow past the sides of the radiator onto the lower part of the engine which i think would be very favorable to keep it cooler. However, i fail to see how this Halltech CAI gets hooked up to what i just described (if in fact, we are talking about the same thing). I dont understand about this 5"/6" hole you mentioned...maybe y ou can send a pic or give me another detailed explanation (??). Thanks. Dave
REPLY: Ok, i didnt think there was any cold air directly to the filter ; if these end plastic pieces are just cut on the front and backside, then its just going to blow into the the entire front portion of the radiator above the shroud as well as onto the lower half of the motor. I dont think this is a very good way of getting cold air to the Halltech Filter because the engine bay isnt sealed on top of the radiator to prevent engine heat from getting at the filter. Agree ? What exactly comes the Halltech CA Induction kit for $129 ?
P.S. I still think it would be a good idea to cut open those end housings though so ram air can hit the lower part of the engine as it goes past the sides of the radiator -- GM should have come up with that idea.
there is no back side, if you were to look at the halltech cai on his website, it is the same piece as stock with the cut hole on each side and a screen infront of each hole...that is the halltech cai kit.. yes, engine bay isn't seal, but outside will help lower under hood temperature...and that has to help since the filter get the air within the engine compartment....btw, if you are going to mod the stock piece, the holes doesn't have to be that big...the front grill open is the limiting factor here....i just drew cut line from the front by the factory grill...it is more like 4.5 x 3.5. hope this helps
I've had the Halltech CAI on for about 9 months. If you relocate the inlet air temperature sensor to the area by the filter intake, you will see that the temperature there is almost identical to the outside air temperature, even in hot weather. The Halltech filter is well positioned and water ingestion is almost impossible. I have driven in strong rains with no problems. As stated before, it would be very easy to modify the existing unit to accomplish the same effect. Be sure and put some type of screen on it to keep out the leaves and trash. Besides, it looks cool!!
REPLY: Man, dont you feel taken advantage of sometimes just because you own a Vette ?! They get $129 for two small pieces of plastic that has a hole cut out in front and back with some mesh on the front ? Im going to take mine out and cut my own holes then reinstall them because i can see that it would blow good around the lower half of the motor. As for the Halltech air filter sitting above the plenum , there wont be much improvement ; the air filter needs to be in a sealed box who's bottom side is cut into the plenum -- in fact since i work with sheetmetal all the time in my trade, im going to make a sheetmetal box for the Halltech to go in then tap into the plenum for 100 percent cold outside air. Ill paint the sheetmetal box flat black so it looks nice and make it easy to remove for when i need to get to the filter. Question : Can you please tell me the approx. dimensions of the Halltech filter so i can get started before it arrives ? Is it larger than the Blackwing filter ?? Thanks much. Dave
i have k&n not halltech, here is the dimension if you want it....18x5x5 inch..when you are done with the sheet metal, post some pictures if want to share your secret.
REPLY: WOW...18" across...that things a monster ! Well, i have a total of 23" width on the plenum, so, it will fit inside the box i make. Thanks much for your help and info . Regards, Dave.
dave, did some temp testing today and here are the data on the cai if you want them.
outside temp 65 degrees
temp under the hood when car is cold 65 degrees also
drove it for 5 miles, outside temp 65 degree still
under hood temp 65 degree also....
after parking the car for 1hr 5 minute while at the gym, under hood temp climb up to 107 degrees.
started the car & headed home, 5 miles later, outside temp 62 degrees.
underhood temp 62 degrees also.
so it does appear these 2 holes are helping keeping the under hood temp close to the outside air temp....as good as the bottom feeder, just missing the ram air benefit.
How about taping up the holes and give us some temps in stock form. Anyone want to bet that the temp is the same when being driven?
too late now, i have a custom grill behind the factory grill, it would be too hard to tape it up....yeah, i will take you on your bet, any amount you can handle.....just to help you out, before the holes were cut when you get done driving and pop the hood open you will feel the hot air coming out...not no more after the holes were cut....you still want to bet?
REPLY: Funny you should report back with this info, as i was going to do the same test today ! Yesterday, i removed the bottom panel to the shroud that fits in the chin , and i neatly cut out the solid sections on each side of it then reinstalled --- wish i would have took some temps before starting the project. Anyway, your findings is very encouraging ; this means i wont need to fabricate a box for the Hallteck filter to sit in and cut into the top of the plenum panel. Looking thru each hole on the sides from the bumper, it appears that most of the ram air might go underneath the car, therefore, im considering making a couple of small metal defectors on a 45 degree angle , or, a small 90 degree elbow ... so the ram air hits them and is directed more upward.
Ive also considered drilling two 1" dia holes directly under the Halltech filter in the top of the plenum which would have a bit of ram air hit the filter directly --- but perhaps this isnt necessary now since the air filter is the same temp as outside.
Thanks for your temp feedback. Very encouraging indeed.
