4 Wheel Alignment (Applies to everyone)
Old Feb 16, 2006 | 08:56 PM
DANK's Avatar
DANK
Default 4 Wheel Alignment (Applies to everyone)
Just had a 4 wheel align done, nothing wrong just wanted to see
if it was off. 6000 miles 06 vert. ALL 4 TIRES WERE OFF
that means everybody else is probably in the same boat
Just wanted everyone to know
DAN
Old Feb 16, 2006 | 09:01 PM
sallen619's Avatar
sallen619
One of the first things I always do is buy a lifetime alignment. I believe that's why I haven't suffered the poor tire wear many Z51 owners have. Don't assume that because the car is new, that the alignment is good.
Old Feb 16, 2006 | 09:04 PM
midnite902's Avatar
midnite902
Had my car aligned at the Ruf Porsche dealer here. They have a 4 wheel laser alignment system. And yes, my car was off even though I paid to have the dealer check the alignment.
DANK's Avatar
DANK
how do you buy a life time alignment?
Old Feb 16, 2006 | 09:06 PM
sallen619's Avatar
sallen619
Everplace I've been to offers it for around $150.00. I bought mine at an authorized Goodyear dealer that is open 7 days a week.
Old Feb 16, 2006 | 09:57 PM
dashotgun's Avatar
dashotgun
alignment is covered under warranty up to 7500 miles btw
Old Feb 16, 2006 | 10:00 PM
sallen619's Avatar
sallen619
That's true. When I got my car (10/29/04), they didn't have the right equipment to do it. It's also easier to make an appointment for an alignment and be in and out in an hour rather than leaving your car at the dealer for a day.
Old Feb 16, 2006 | 10:05 PM
davidfarmer's Avatar
davidfarmer
there is a huge "allowance" in the OEM alignment, so do you mean yours was off of the ideal, or actually out of the acceptable range? Unless you actually have something come loose in your suspension, alignments don't really move in these cars. If your alignment was waaayyy out of the "allowance" range, then you likely have a problem
** If you want something down right, do it yourself.
http://www.metricchemical.com/align.PDF
Old Feb 16, 2006 | 11:03 PM
rosemaryburm's Avatar
rosemaryburm
From: Heaven, for the climate; Hell, for the company
I don't mean this to sound like a stupid question. Do you have to report "symptoms" to the dealer, or can you just ask for a free alignment?
Old Feb 16, 2006 | 11:06 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
3 of mine were in spec, one was out by 4x the limit when I had a preemptive alignment done.
Old Feb 17, 2006 | 12:00 AM
lytmup's Avatar
lytmup
Are you sure that you bought this alignment for a Corvette? 150 for lifetime sounds right for normal cars, BUT I found that no place will warranty a Vette's alignment longer than 1 year.
And in addition to that, the alignment itself is 3 to 4 hours of labor, which is around 200+ dollars.
Old Feb 17, 2006 | 12:10 AM
mlongo99's Avatar
mlongo99
Cruise-In VIII Veteran
You can just tell them that it pulls to one side. You may have to "remind" them that alignment is covered for 7500 miles, but if everything is within their tolerance, I don't know if they will want to charge you or not.
Old Feb 17, 2006 | 12:23 AM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
They'll probably have a Tech drive it first. He'll report back that everything is fine. Then they'll say that it felt normal, and they're gonna charge you if you still want one.
Old Feb 17, 2006 | 12:24 AM
Mel 2001's Avatar
Mel 2001
Just had mine done at dealer last Tuesday. 1100 miles on my C6 06. Car pulled to the right. Steering left of center to drive straight. Right rear way off and left rear also out of acceptable range. OK now. Never had to touch my C5 had 45000 miles on it.
Old Feb 17, 2006 | 07:47 AM
jruss361's Avatar
jruss361
DAN
Were you showing any unusaul tire wear?
Were you paying for theis alignment?
The specs are so broad I would question all four wheels being out of alignment unless you have lowered the car.
After owning a C5 I purchased a Caster/Camber gauge. My C6 looks good!
Old Feb 17, 2006 | 10:05 AM
haljensen's Avatar
haljensen
The factory alignment specs are pretty broad, you can be out of alignment and still be within factory specs.
I had my car aligned at a privately owned competion alignment shop to the exact specs that I wanted for $99.95. Every setting was off on the original alignment, with most settings just barely out of the factory recommended tolerances.
Suggestion for the people lowering their cars; GET AN ALIGNMENT! Changing the height effects all the alignment settings. If your car was barely in tolerance to begin with you are probably way out after lowering.
Old Feb 17, 2006 | 11:31 AM
clambros's Avatar
clambros
This might be slightly off-topic, but I found a Tire Dealer here in Atlanta that will do a 4 wheel laser alignment for $120 .. anyone think this is good or bad ??
When I checked with my dealer, they don't have a laser alignment shop, or an "on the vehicle" balancer.
Sounds like cheap tire insurance ??
To 4 Wheel Alignment (Applies to everyone)
Old Feb 17, 2006 | 11:34 AM
AutoCutter's Avatar
AutoCutter
Excellent Guide, David, Thanks!
Old Feb 17, 2006 | 02:12 PM
bradb's Avatar
bradb
Anyone know where I can get alignment specs on-line? Thanks.
Old Feb 17, 2006 | 08:10 PM
1Fastline's Avatar
1Fastline
On the last three sports cars I bought new the alignment was off. Always a good idea to have it checked!
