I looked in on the install just about every day. I wouldn't do this at home unless you have one hell of a shop and tools to do the mods. I recommend a shop like FCCT. They have done many installs and knew what they were doing.
Well I have a full engine shop at my disposal...10 lifts..machining tools...etc etc..
I just dont have the electrical knowledge to do it right. I need someone with tech skills .. I know I could tear it apart and bolt it up .. its not rocket science.
Your probably right. I don't have the access to a shop to do the work. Some of the things I didn't feel comfortable doing were:
Drilling the Harmonic balancer
Lowering the radiator, housing, and supports.
Re-routing hoses and other parts on the front of the engine.
I don't know anything about the electrical parts either. It was just easier having a shop that has done it before perform the work
I wanted to add one thing. This question is for anyone that has a procharger in their car. My front air dam (Black plastic piece under front end) sits only about 2 inches off the ground. Is this normal?
Mine scrapes quite often. I figure the more I drive it the more it will file itself down.
On your dyno sheet, you air to fuel ratio looks like its going lean up top. Are you losing fuel pressure or is the just the Ati tune??
To be honest with you, I couldn't answer that. The Air/fuel meter reads right on during the runs. I will check with the guys at the shop.
I'm not technical enough....yet. I'm still learning. Thanks for the feedback.
Nice numbers How do you like the doors? Which kit did you get?
The kit used on my car was "Vertical Doors Inc." I did a lot of work researching the doors and word of mouth said these guys were the best. The doors are great. Makes the car stand out. Just remember, it takes a little inside door triming, so think hard before doing it. You can't see the mods from the outside.
Why do you have to drill into the harmonic balancer?
To be honest, I'm not sure. I believe you have to pin the harmonic balancer to the crank because the harmonic balancer only has a key. It could slip. ATI provides the drill bit for drilling.
What are you going to do for traction ?? Run drag radials all the time or tub and put 345's on ???
Right now I'm running 325's on the back. No tubbing required. I will need drag slicks for the track. On the road, unfortunately, I just have to be careful.
Actually there is no key in the stock balancer. Its a press fit from the factory. If you don't pin(install a key) in the balancer, the extra load on the belt system is known to spin off the balancer and bolt causing crank and power steering rack damage
