LS2 Filter Bypass Valve
Old Feb 19, 2006 | 12:53 PM
JmpnJckFlsh's Avatar
JmpnJckFlsh
Default LS2 Filter Bypass Valve
Anyone with a 2005 service manual...can you help me out.
The LS2 has spring-loaded ball check valve in the block to bypass oil flow around the oil filter if the filter is stopped up. Does anyone know the differential pressure specification across the filter for the bypass valve to open? Based on my "other life" experience, I would think it would be about 20-25 psi...anyone know specifically?
Another related question: I presume the oil pressure reading shown on the dash gauge is downstream from the filter, i.e. measured at the galleries feeding the main bearings...Can anyone confirm?
Old Feb 19, 2006 | 01:30 PM
VET4LES's Avatar
VET4LES
The pressure sending unit is on top of the engine, drivers side under the power brake vacuum hose. (shown on page 6-106 in the service manual) The oil flows from the filter up to the lifters and then down to the rod bearnings. The pick up in the bottom of the pan feeds the pump which feeds the main bearing before it goes through the filter.
I think the bypass valve you are talking about is in the filter. There is a pressure relief valve bolted to the filter housing. It maintains the proper pressure in the block. If it also is a bypass valve the manual does not tell the pressure. ( This is on page 6-290) Hope this helps.
Old Feb 19, 2006 | 01:35 PM
davidfarmer's Avatar
davidfarmer
I would think it is lower than 20. I only know one person who has ever had a filter blockage issue, and their oil pressure was really low, like 5 psi. Changed filter, all was fine
Old Feb 19, 2006 | 01:42 PM
AFTERBURN's Avatar
AFTERBURN
19 psi is when the valve begins to open (bypass).
The sensor is after the filter, the filter dampens the pressure signal so the sensor doesn't experience significant spikes, causing sensor failure.
And to clear up any previous misquote, there are no bearing that are lubricated with unfiltered oil unless the filter is in bypass mode.
Also, the filter bypass does protect against a pluged filter although that is not the actual purpose for the valve, but rather to protect against an over pressurized filter due to cold start up. Very cold weather.Pressures over 150 psi can cause the filter seal to blow out and can cause the filter can to leak at the seam holding the can to the base plate.
Old Feb 19, 2006 | 02:07 PM
JmpnJckFlsh
Wow...great info! Thanks, guys.
To clarify for some that could misread it, the 19 psi is the DIFFERENCE in oil pressure between the upstream side and the downstream side of the oil filter...NOT the absolute value of the oil pressure. This means, if your oil pressure gauge is reading 70 psi when cold, considering the maximum pressure drop across the filter (assumes bypass opened; depends on the oil temperature), the oil pump could be generating up to 90 psi or more.
It would be interesting to know at what differential pressure the filter media begins to collapse (if the bypass didn't exist or open), but I presume that leaks and other more obvious bad things happen before that.
People never know about all the stuff engineers do that keeps them out of trouble.
To LS2 Filter Bypass Valve
