Question about removing the rear adjusting bolt/bushing
I wanna remove the rear adjusting bolt so I can cut the bushings. I was able to detach the sway bar, remove the bolt connecting the lower A-arm to the shock, but now I'm stuck. There is a vertical bolt that holds the bottom A-arm to the suspension but I'm not sure how to loosen it. What do I need to get it off?
You can either disconnect the 2 control arm bolts, where it connects to the subframe. Or you can disconnect the ball-joint, where it connects to the upright/spindle.
The ball joing may be more difficult.
If you disconnect the concentric bolt, remember to mark the location with a sharpee, or you'll screw up your alignment.
How do you tell which one is the concentric bolts? First time I have heard anyone suggest to mark anything??
My ball joint popped right off. I just tapped it with the 5lb hammer and it came right off. Easy-squeezy
what tool did you use that fit over the nut on the ball joint and had clearance from the CV boot? I couldn't figure out a way to get mine off, so I'm holding off for now.
