Oil changed today
Old Feb 28, 2006 | 08:55 PM
nuvetteowner's Avatar
nuvetteowner
Default Oil changed today
I just had the oil changed today in my 05 c6,was there anything else I should have done?
It was the first oil change ,and I didn't have the luxury of time to go to the dealer for this.They checked the differental and all the fluids.I was in and out in 10 minutes,and only cost me $57.00.
I stopped in a texaco oil change shop,they had the mobil one.
Old Feb 28, 2006 | 08:58 PM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Smart move. Cultivate the guy's at the local quick lube. Soda, pizza. It will pay off in the long run.
Old Mar 1, 2006 | 09:09 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
If it's a Z51 not a bad idea to lube the grease fittings on each end of the rear sway bar at each oil change.
Old Mar 1, 2006 | 01:32 PM
C6 ROLLER's Avatar
C6 ROLLER
I bring a pizza and soda for the guys and drop off a 6 pack every so often. They take great care of me and the car. They change the oil and the procharger fluid every 5,000 miles for me.
Old Mar 1, 2006 | 02:43 PM
victory_C6's Avatar
victory_C6
I have never greased a grease fitting. Any tips on what I need and how to do it. I am getting a squeak in the rear, and I am hoping this might resolve the problem. Thanks in advance.
Old Mar 2, 2006 | 03:15 AM
matuszynski's Avatar
matuszynski
here u go.
http://forums.corvetteforum.com/show...4&forum_id=101
Old Mar 2, 2006 | 02:18 PM
victory_C6's Avatar
victory_C6
Originally Posted by amy.l.l
That's great, thank you.
Old Mar 2, 2006 | 03:58 PM
stabori's Avatar
stabori
St. Jude Donor '08
Fill it back up with some 0W40
Old Mar 2, 2006 | 07:22 PM
LS1LT1's Avatar
LS1LT1
Good oil, I have that in my Z28 right now. Either that or the 5W40 are most likely the only Mobil 1 synthetics I would use.
I'm putting Amsoil 0W30 with an Amsoil filter in my C6 tomorrow.
Old May 7, 2006 | 03:56 PM
Altc's Avatar
Altc
Be carefull of the service lifts some lift by the frame others you drive onto they lift by the wheels.The latter is better to avoid cracked rocker panels
Old May 8, 2006 | 01:22 PM
LS WON's Avatar
LS WON
/Where did you go? Jiffy Lube or Walmart?
Old May 8, 2006 | 05:36 PM
Tavarez's Avatar
Tavarez
Get yourself some Rhino ramp 12000, also get you some RP synchromax... RAaaWwr!
To Oil changed today
