Do all aftermarket shifters buzz?
Old Mar 3, 2006 | 11:08 AM
EuroRod's Avatar
EuroRod
Default Do all aftermarket shifters buzz?
My B&M is coming out the weekend, and the stock shifter is going back in. Does any one have experience with other shifters and pass it along here? I think the Calloway is the most expensive, and it's gotten good comments in this forum. But, does it also buzz? The B&M makes this car sound like a Kia with 100k on the odometer!
Old Mar 3, 2006 | 04:19 PM
AFVETTE's Avatar
AFVETTE
My experience is with C5's and for the most part it wasn't the shifter that rattled and buzzed it was the ****. The factory **** almost always made noise as did many aftermarket ****'s. I went through 5 before I found one that didn't make noise. MGW, they have since stopped making Corvette accessories. Too bad they manufactured great stuff for the C5.
Hope this helps.
Tom
Old Mar 3, 2006 | 04:41 PM
02impactblue's Avatar
02impactblue
my stock shifter buzzes in 2nd and 3rd at 3500 rpms started at 900 miles.
Old Mar 3, 2006 | 06:07 PM
AintQik's Avatar
AintQik
Before you take it out try and insulate the **** or try a different ****. I've had this on a few aftermarket shifters and it was the **** not the shifter itself. I got this speech from somebody and thought they were insane because it sounded in no way like it was related to the ****. But, I tried it and it worked like a champ. I actually switched ***** in my case.
Old Mar 3, 2006 | 06:40 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
It's the ****. Not the shifter.
Old Mar 4, 2006 | 08:32 AM
EuroRod's Avatar
EuroRod
Sorry guys, but it's definitely the shifter. I can grab the shifter below the ****, through the boot, and hand-dampen the buzz.
Old Mar 4, 2006 | 09:46 AM
xs650's Avatar
xs650
You may be right, but doing that would also stop the **** from buzzing.
Old Mar 4, 2006 | 09:54 AM
haljensen's Avatar
haljensen
Couldn't find the post with a search but somebody posted earlier on this Forum that they had used silicone gasket material between the **** and the shaft and reduced the rattle.
Old Mar 4, 2006 | 10:32 AM
nicky D's Avatar
nicky D
i am working with a hurst research specialist here in GA i have now tested the B&M calloway breathless performace hurst with straight stick and bent, also a custom shifter that has stockinternals and they created a new base that moved the pivot point which gives the short throw like the rest it is the least noisy and second best is the breathless. any questions let me know nickyd83_28@hotmail.com
Old Mar 4, 2006 | 10:49 AM
xs650's Avatar
xs650
A modified base would be easy to make for anyone with a milling machine.
Do you know what it takes to move the pivot on the shift lever?
Old Mar 4, 2006 | 10:50 AM
davidfarmer's Avatar
davidfarmer
mine is also the shifter, not the know
Old Mar 4, 2006 | 11:11 AM
tfenton's Avatar
tfenton
I have no problem with my B&M. I added extra insulation ... I did have some rattle but discovered it was the ****. Swapped it out and no issues now!
Old Mar 5, 2006 | 12:24 AM
DDSLT5's Avatar
DDSLT5
Hurst here - not a peep!
Old Mar 5, 2006 | 02:02 AM
Tavarez's Avatar
Tavarez
I just installed my B&M, didn't get any vibration... i'll see if I notice anything later.
Old Mar 5, 2006 | 06:36 AM
Jagcvette's Avatar
Jagcvette
No problem with my B&M.
To Do all aftermarket shifters buzz?
