New Callaway SuperCharged Corvette, 560 bhp
One option that's not mentioned in this literature yet is a Z06 fender/fascia package that we're offering. Price is $6,695 for the Coupe Kit, $7,695 for the Convertible Kit when purchased with the SuperNatural or SuperCharged C6. The Kits include front carbon fiber Z06 fenders, rear Z06 OEM material fenders, Z06 front fascia and required inner fenders and bracketry.
If you're considering a Z06, this is an excellent alternative. Especially if you want paddle-shift or drop-top.
For more info, ask here, e-mail me at mvendetto@callawaycars.com
or call (860) 434-9002, 8:00-5:00 Eastern US time, Mon-Fri.
Does this have to be done by you, or can a local installer do the project if we live far away?
Craig, go to the Callaway website and look at the prices before you get too excited. The prices quoted are for the fender/facia.
Jeff
SuperNatural 490 hp Package: $13,950.
SuperNatural 550 hp 7.0L Package: $30,900.
Supercharged:
SuperCharged 560 hp Package: $16,995.
The above packages include Callaway badging and authenticity documentation, as well as other Callaway-branded components as listed in the literature. All of these packages are installed at the Old Lyme, Connecticut factory. If you buy a new Corvette, the Chevy dealer can coordinate shipping the car from the dealership or directly from the Bowling Green assembly plant to Callaway for modification.
If you want to have a local shop do the installation, you certainly may. The SuperNatural and SuperCharged Callaway badging is not available separately, but all other parts are:
The 490 hp powertrain components (PowerGroup 1, 2, and 3) are priced at $9,810.
The 550 hp/7.0L SuperNatural crate engine is priced at $26,300.
We're not offering a Supercharger in kit form for C6 yet as a standardized calibration is not ready to release to the marketplace.
As a Callaway Twin Turbo Corvette owner, I am glad to see Callaway getting back into the forced induction business
Jeremy
I'll have all package details on the www.callawaycars.com website early next week.
Seems there are lots of people just getting the wider rear fender so they can put more meat down in back.
We're using all GM parts for our Z06 Body Option. If there's enough demand for a rear-fender-only Kit, we could potentially tool up for new rear fenders that match the fronts cosmetically while maintaining the Z06 basic dimensions to accommodate wider wheels and tires. The Kit would also require new GM inner fenders, vent bezels and brake cooling ducts. What do you think a fair price should be?
The issue with the Vert panels is the upper area by the door is narrower than the coupe. This area needs to be cut, remolded for the tonneau cover and reinforced.
Since you are already apparently doing this modification for a vert kit it would seem reasonable you would offer this option for somebody who only needs the rear render panels.
What is the boost to get 550 hp
Hamad
Maybe I was being unclear. The reason we don't plan to offer a rear-only kit using the GM fenders is because the flat around the wheelwell opening is narrower on the Z06 fender, not because of the mod you mentioned that's required adjacent to the tonneau. I've attached some photos of a partially mocked-up convertible with Z06 fenders so you can see the difference in appearance that we're concerned about. Am I understanding you properly? When you write "that's not the question", do you mean that we're overreacting to the mismatch in fender appearance, with the rear fender wheelwell opening looking different than the front?
Hamad
Callaway offers three options for the C6:
1) SuperNatural 490
naturally aspirated (no supercharger), using the original 6.0L LS2 short block, adding new cylinder heads, cam and valvetrain components and intake and exhaust mods.
2) SuperNatural 550
naturally aspirated (no supercharger), using a new 7.0L/427 cid GM Motorsport block-based engine with premium quality internals and similar cylinder heads, cam and valvetrain components and intake and exhaust mods.
3) SuperCharged 560
Roots-style Eaton supercharger installed on the stock 6.0L LS2 engine. No other internal engine mods are required.
Callaway provides authenticity documentation when we install the above packages. The cars become "Callaway SuperNatural" or "Callaway SuperCharged" Corvettes. If the whole package isn't desired, most of the components are also available individually.
To omit the Double-D exhaust, you'd be purchasing the Honker only @ $390. instead of $1,425 for PowerGroup 1. There would be a net savings of $1,045.
