C6 Z06 Catback?
Old Mar 24, 2006 | 07:37 PM
glennhl's Avatar
glennhl
Default C6 Z06 Catback?
It appears to me that the C6 Z06 catback should fit on a stock C6 if you use a 3" H or X pipe. The cool thing about the Z06 are the built-in cutouts. Has anyone done this and if so, how expensive is it?
Thanks,
Glenn
Old Mar 24, 2006 | 09:01 PM
cerino2000's Avatar
cerino2000
As soon as I can get a Z owner to sell me their stock stuff cheap when they get aftermarket, I plan on trying it out.
Old Mar 24, 2006 | 11:11 PM
glennhl's Avatar
glennhl
What do they cost from the dealer or gmpartsdirect.com?
Old Mar 26, 2006 | 10:43 AM
Bandit1's Avatar
Bandit1
You don't want to know.
Old Mar 26, 2006 | 10:48 AM
SpinMonster's Avatar
SpinMonster
Every other part blew me away by being cheaper than expected. I don'y the exhaust will break the trend. Problem is that the cutouts are vacuum operated, not electrical.
Old Mar 26, 2006 | 11:41 AM
glennhl's Avatar
glennhl
Why is the vacuum a problem? The best I can figure is that the vacuum holds the cutout closed and that when you floor it and the vacuum goes away it lets the cutout open. Some people sell a switch which I figure must be a solenoid valve that when you close the valve and kill the vacuum it allows the cutout open.
So all you need to do is run a vacuum line from the intake manifold back to the cutout. No big deal.
Does anyone have the part number so I can look it up on gmpartsdirect.com?
Thanks,
Glenn
Old Mar 26, 2006 | 11:44 AM
cerino2000's Avatar
cerino2000
Ya but I believe the switch is electrical (thus all the posts about removing the fuse) and the vacuum actuators would be part of the exhaust. I am thinking window switch (i.e. as in from a nitrous set up) to kick it in.
To C6 Z06 Catback?
