I had problems with mine on my 06 M6 to the point I called SLP and talked to them about the bridge not fitting, They told me that it will not fit in the stock mount and that it should be OK. after working with it for two evenings I gave up, it never fit right and I had to force it together. I ended up taking it back off and replaced it with a Halltech.
Good luck.
Good luck.
Why would they say this when it obviously fits without a problem?????
I just installed one this past Sat. Fits as good as the OEM air bridge, after I turned the mounting bracket around. I think their photos/instructions aren't very clear:
I had a Blackwing on my 01 and on my 04 corvettes and they fit fine, there was no way to get the c6 version I had to fit on my 06, it was not because I did not try! The bridge I had did not even look like the one in the picture,
