I think, but not 100% sure, that the fronts are 8.5 x 18 with 53mm offset, rears are 10 x 19 with a 63mm offset. Bolt pattern is 5 x 120mm. To be sure, check with Tire Rack or another wheel distributor. Good luck.
The ones given as metric decimal values are conversions from fractional inch sizes. 120.65mm = 4.75 inch
Edit added 20 April:
My stock C6 wheels have the dimensions molded in in recesses between the stud holes on the back side of the wheel.
Front 18x8.5Jx56
Rear 19x10Jx79
1st number is wheel diameter in inches, 2nd is rim width in inches with the J being the rim profile where the tire mounts, 3rd number is the offset in mm.
