Coolant temperatures
Old Apr 1, 2006 | 12:54 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
Default Coolant temperatures
I was wondering what most of the rest of you guys are running temperature wise on your coolant. I feel that Mine is running hotter than it should be. While driving down the Highway I’m running 198 deg. If I pull in some place in line to get something to drink or eat it quickly jumps up to 210-215. Is this normal. A while back I tagged something in the road and took out some of the aero dynamic under the car. It has since been replaced but I was wondering if maybe the fan had some how become unplugged. All the wires for the horns and other things are on that side of the car.
Old Apr 1, 2006 | 01:05 PM
EuroRod's Avatar
EuroRod
What ambient outside temps? For warm temps, sounds about right with stock t'stat.
Old Apr 1, 2006 | 02:27 PM
cbrf4i1's Avatar
cbrf4i1
yup that does sound right for stock stat....i have 160, on the free way / or constant air flow situation.....dic will show 176-178 all day.
Old Apr 1, 2006 | 03:11 PM
davidfarmer's Avatar
davidfarmer
up to around 220 is perfectly normal, and is as designed for clean emmissions
Old Apr 1, 2006 | 04:04 PM
Mocoso's Avatar
Mocoso
Yep I agree with everyone.. numbers sound dead on
Old Apr 1, 2006 | 07:41 PM
Vette_DD's Avatar
Vette_DD
The coolant temp. on my 05 C6 usually runs about 198 deg. unless I'm on the interstate at 75 MPH, then it runs about 192-194.
If I get in a fast food line for 5 minutes or more, it'll slowly creep up to 205-210.
Sounds like yours is about right.
Old Apr 1, 2006 | 08:29 PM
VET4LES's Avatar
VET4LES
Your running exactly the same as mine.
Old Apr 2, 2006 | 06:23 PM
nuvetteowner's Avatar
nuvetteowner
Dont worry all is normal,I idle in rush hour traffic at sometimes 217! the aluminum engine is designed to run hot.
Old Jun 12, 2006 | 02:19 AM
COALMINER,KY's Avatar
COALMINER,KY
all corvettes temp flucuates, i had a 1984,a 1991, and a 2006, and they all ran at least 220, in traffic but cooled quickly when i got back on the highway
Old Jun 12, 2006 | 05:38 AM
timd38's Avatar
timd38
Mine are the same also.
Old Jun 12, 2006 | 06:19 AM
06corvette's Avatar
06corvette
and mine is the same. if I change my stat to 160 is it going to have better performance??
Old Jun 12, 2006 | 02:57 PM
LS WON's Avatar
LS WON
Mine varies in range from 192 to 226.
Old Jun 12, 2006 | 08:58 PM
JohngC62005's Avatar
JohngC62005
Mine runs right at 195 with stock t-stat and never even sitting in traffic goes over 205 due to the fan being reprogrammed.
Old Jun 12, 2006 | 10:58 PM
k0bun's Avatar
k0bun
From: NJ..."the way I saw it, everyone takes a beating sometimes."
You eat fast food in your Vette?!
Old Jun 14, 2006 | 06:25 PM
Blue 2006
Guest
Posts: n/a
I have a 160 f stat ; once i get moving i maintain between 174-176 f on the coolant and between 196-202 f on the oil. This is between 1600-2500 rpms regardless of speed , regardless of outside air temp. and regardless whether the A/C is on or not, thus far. (the highest outside temp. since ive had the 2006 vette has been about 85 f.). When i had the factory stat, the coolant and oil temps were much higher.
Old Jun 14, 2006 | 06:48 PM
d_bravo33's Avatar
d_bravo33
192 to 212 so far, highway vs. traffic. Stock thermostat.
Does anyone know the optimum (coolant and oil) temperatures for the LS2, and why? I know what the manual says, but wonder how tuners feel.
To Coolant temperatures
