intake and brakes
Old Apr 1, 2006 | 01:05 PM
ffbor750's Avatar
ffbor750
Default intake and brakes
two questions......
1. i just put in a kn intake. can i remove the screen on the mass air sensor? can i take off the plastic under the intake and the one that covers the radiator?
2. does anyone have sqeaky brakes? i have 6000 miles and they started acting up 1000 miles ago. doesn.t matter when..they squeal when i hit the brakes. driving me crazy
any reply is appreciated
Old Apr 1, 2006 | 01:12 PM
User 81424's Avatar
User 81424
Do you have a Z51? Ceramic pads will eliminate the squeaking, but stopping distance is a tad longer.
Old Apr 1, 2006 | 01:13 PM
Indy-hp's Avatar
Indy-hp
St. Jude Donor '09
Don't have a clue re #1, but go read the C6 FAQ thread on "bedding the brakes," that will take care of your squeeky brakes pronto.
Old Apr 1, 2006 | 01:24 PM
ffbor750's Avatar
ffbor750
i have a basic '05 c6
Old Apr 1, 2006 | 02:46 PM
cbrf4i1's Avatar
cbrf4i1
Originally Posted by ffbor750
two questions......
some folks have remove the screen on the mass air with out problems...this one is a tough call,...i personally wouldn't since i don't have a local tuner that can tune on 06. if you are referring to the radiator shroud, don't remove this, if help direct air into your ac condenser and radiator.
just do a couple hard stops from high speed, it will go away.....and it will come back later also....
To intake and brakes
