??? about TPMS and custom rims
Old Apr 1, 2006 | 02:32 PM
weelycrazy's Avatar
weelycrazy
Default ??? about TPMS and custom rims
Can you remove the TPMS from factory rims and put them on custom rims? I am looking at buying either some foose or Niche rims and wanted to be sure I could re-use the factory TPSM. This is for a 2005 C6. Thx
Old Apr 1, 2006 | 03:42 PM
ByByBMW's Avatar
ByByBMW
St. Jude Donor '06-'08-'10-'11-'12-'13 '14-'15-'16-'17-'18-'19
If your new rims will accept the sensors then yes you can swap them over. It will depend on the new rims and I don't have any idea how to tell you if they will fit or not.
Hope this helps a little bit.
Old Apr 3, 2006 | 12:07 AM
weelycrazy's Avatar
weelycrazy
Thanks, I'll just call the manufacturer before I purchase.
Old Apr 3, 2006 | 02:06 AM
hodgeee's Avatar
hodgeee
There is a specific indent in the rim for the sensor, manufacturer will specify if monitor will fit.
Also good news, I found out that if you rotate from side to side with our asymetrical designed tires, that the sensors reprogram themselves to the side that they are on. I have done this 3 times now due to a lot of track use and found that it works everytime, but may take a day or two.
Old Apr 3, 2006 | 11:03 AM
ByByBMW's Avatar
ByByBMW
If that really is true, thats good to know.
To ??? about TPMS and custom rims
