Magna Flow Mufflers
Old Apr 5, 2006 | 12:26 AM
kca009's Avatar
kca009
Default Magna Flow Mufflers
Need information on the magna flow mufflers, heard adding the whole cat back is a waste of money
Old Apr 5, 2006 | 12:16 PM
cbrf4i1's Avatar
cbrf4i1
just do only the mufflers. save your money on the cat back, unless you might want to go back to stock someday.
Old Apr 5, 2006 | 01:19 PM
sd455ta's Avatar
sd455ta
I threw the mufflers in the trash after one week, the drone & resonance was so bad!!!
Old Apr 5, 2006 | 01:22 PM
Walt White Coupe's Avatar
Walt White Coupe
Old Apr 5, 2006 | 01:57 PM
06C6FVR's Avatar
06C6FVR
I bought just the magnaflows and it sounds great, with little to no resonance or drone. I spent $215 installed. I have taken a couple people for rides and they commented that it is how the car should sound from the factory. I love it and it is better than spending $1k. Plus I picked up 8 RWHP and 8 RWTQ on the dyno from them
Daren
Old Apr 5, 2006 | 03:59 PM
cbrf4i1's Avatar
cbrf4i1
Daren
you sure know where to go to get that install......i must have gone to so many different places and no one would touch them...finally the last place after showing the pictures from cf they figure they can do the job and charge me $250 for 2 hrs of work...i do have drone at around 1500-1900 under partial accel, how come you don't have any? did you get the 2 1/2 or 2 1/4 mufflers? thanks
Old Apr 5, 2006 | 05:06 PM
06C6FVR's Avatar
06C6FVR
I got the 2 1/2", I said little resonance...it is about the RPM you are talking about, but I like the way it sounds, not nearly as loud as my B&B PRT's I had on my C5. Also, mine is a 6 spd, is yours an auto, as I have heard it is worse on the auto's. With a 6 spd, you can also drive around most of the drone that any of the aftermarket mufflers or systems produce...just change the gear. IMHO... Im very satisfied with the sound. And yes, i found a shop near my house that works on these and has installed several of them on other C6's. It only took them about 2 hrs to do.
Daren
Old Apr 5, 2006 | 07:15 PM
cbrf4i1's Avatar
cbrf4i1
i have a manual, to me the drone is louder in that rpm range then high rpm under wot...if your the same way....i would have like it louder in the upper rpm range instead of 1500-1900rpm. has your car gone any faster then 12.2x @ 115 yet with the magnaflow?
Old Apr 5, 2006 | 07:50 PM
06C6FVR's Avatar
06C6FVR
No, When it got cold the other day, i was having major traction problems. It dyno'd at 370 RWHP and 365 RWTQ with magnaflows and the tune. The worst pass without spinning was 12.40 and best without spinning was 12.26
Daren
Old Apr 5, 2006 | 08:04 PM
Fore58's Avatar
Fore58
Daren
370hp/365 is awesome for just the magnaflow mufflers and tune. Was that the hp tune? That's where I want to be with minor mods.
Old Apr 5, 2006 | 08:42 PM
06C6FVR's Avatar
06C6FVR
It was with LS2 Edit from MTI on the dyno. It got 12 RWHP and 12 RWTQ from the tune, and the other 8 from the mufflers.
Daren
Old Apr 5, 2006 | 08:47 PM
Fore58's Avatar
Fore58
Daren
Daren,
Which tips did you use? Can I use the stock tips, cut off and weld to the magnaflows?
Old Apr 6, 2006 | 03:48 AM
06C6FVR's Avatar
06C6FVR
I used the stock tips, they just welded them onto the magnaflow mufflers
Daren
Old Apr 6, 2006 | 07:36 AM
plstkr67's Avatar
plstkr67
You might consider Flowmasters...for 409.00 delivered to my house then another 130.00 & 1/2 hr. at Midas they were on. I am very happy with these...they look great with the larger single tips rather than double and there is no drone. I have a M6...maybe the autos are having the problem or possibly the pipes are touching the frame for those that are unhappy.
Old Apr 6, 2006 | 09:37 AM
Homer3D's Avatar
Homer3D
Here is what I had done:
2 Magnaflow muffles, model number 14336
Cut off stock mufflers at the inlet
Cut off stock tips at the outlet
Weld stock tips on the Magnaflow mufflers
Weld new mufflers at the orginal location
Install pics and before/after videos here
Old Apr 6, 2006 | 01:35 PM
Fore58's Avatar
Fore58
Daren
Does Midas sell the magnaflow mufflers plus installation of the stock tips?
Old Apr 6, 2006 | 02:43 PM
06C6FVR's Avatar
06C6FVR
I dont know, you can get the mufflers online though
Daren
Old Sep 24, 2021 | 08:37 PM
Tim H's Avatar
Tim H
I just ordered the Flowmaster cat back and will gut the cat and new front down pipes without the precats, I hope it’s loud!
To Magna Flow Mufflers
