CLUCH PROBLEMS help
Old Apr 10, 2006 | 09:31 AM
BIGGDOGG1's Avatar
BIGGDOGG1
Cruising
Default CLUCH PROBLEMS help
I was driving my 05 z51, some times the cluch sticks to the floorboard then pops back after a couple of seconds,but last night it stuck to the floor now i cant stick it in reverse. did i burn up the cluch or are there any similar problems?
Old Apr 10, 2006 | 09:40 AM
vetdude's Avatar
vetdude
You obviously haven't heard of the recall yet. Click on the link below:
http://temp.corvetteforum.net/c5/ken...heelrecall.pdf
Good luck!
Old Apr 10, 2006 | 09:42 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
This is a known problem with the c5 and I guess the c6 also. Have you tried to pop the pedal up with your toe?
Old Apr 10, 2006 | 09:59 AM
valdeztke's Avatar
valdeztke
Vet dude - Dead Link
The only time my pedal ever stuck was when I rode the heck out of it ....
Old Apr 10, 2006 | 10:22 AM
BIGGDOGG1's Avatar
BIGGDOGG1
Cruising
Default Vettedude
I Cant Get To The Link You Prvided
Old Apr 10, 2006 | 10:23 AM
BIGGDOGG1's Avatar
BIGGDOGG1
Cruising
Default Not Mee
I Tried To Pull It Up With My Toe,this Happened Before,but This Time I Cant
Old Apr 10, 2006 | 10:36 AM
BIGGDOGG1's Avatar
BIGGDOGG1
Cruising
I WENT OUT THIS MORNING AND SEEM LIKE EVERYTHING IS OK NOW,BUT I WAS DRIVING THE HECK OUT OF IT LAST NIGHT
Old Apr 10, 2006 | 11:46 AM
GentleBen's Avatar
GentleBen
Cruise-In 7-8-9-10-11-12 Veteran
Wounded Warrior Escort '11
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
See if this describes your problem: http://www.corvetteactioncenter.com/....php?qstId=562
Old Apr 10, 2006 | 01:43 PM
BIGGDOGG1's Avatar
BIGGDOGG1
Cruising
Default Genalben
I JUST GOT IT TOWED TO HOOD CHEY IN COVINGTON LOUISIANA,AND I GAVE THEM THE BULLINTEN NUMBER,WOULD THIS BE COVERED UNDER WARRANTY
Old Apr 10, 2006 | 02:37 PM
VET4LES's Avatar
VET4LES
Should be but if they see burned or hot spots on the flywheel they could give you a hard time.
Old Apr 10, 2006 | 09:27 PM
carboman's Avatar
carboman
My clutch did the exact same thing. Checked the fluid and it was dark and murky. Changed out the fluid and all is well.
Old Apr 10, 2006 | 11:00 PM
calemasters's Avatar
calemasters
Good luck!
2005 MY vehicles are not affect by the 2006 clutch recall.
Old Apr 11, 2006 | 12:15 AM
BIGGDOGG1's Avatar
BIGGDOGG1
Cruising
Yes It Was Black And Murkey,they Got My C6 Off The Tow Truck And The Repair Man Backed Into A Blazer Now I Have Bigger Problems
Old Apr 11, 2006 | 06:56 AM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
THats not good
Hope all goes well.
Old Apr 12, 2006 | 04:18 AM
COOLPEZMAN's Avatar
COOLPEZMAN
Best of luck to you
To CLUCH PROBLEMS help
