How fast has anyone driven a C6?
Old Apr 12, 2006 | 07:09 PM
  #41
2vettes's Avatar
2vettes
Originally Posted by vette-oholic
It has been discussed many times that top speed is achieved in 5th gear....
That's what I told, too. I don't have any place to try that level of triple digit driving, so I have no bragging rights.
Old Apr 12, 2006 | 11:54 PM
  #42
promod69camaro's Avatar
promod69camaro
Originally Posted by Gearhead Jim
If top speed for a M6 Corvette is truely 186 mph, I'm guessing that the A6 would top out at about 180. You lose about 20 hp more due to the automatic, plus you loose about another 20 hp because the engine can only get up to 5,000 rpm in 5th gear. Taken together, that's 40 hp additional loss, or 10%. Since drag increases as the square of the speed, a 10% power reduction should produce a slightly more than 3% speed reduction. 3% of 186 = 6 mph.
Other folks are requested to calculate and post here...
I don't see why you state we loose HP for having an automatic. With a lock up torque converter, there is no torque converter losses, and the internal clutches are locked up, so where would the losses for the automatic be? In drag racing, we are now using automatics with lock up torque converters. The key is the locking torque converter.
Old Apr 13, 2006 | 12:21 AM
  #43
jayp2423's Avatar
jayp2423
183 in 5th...MN6 non Z51 on a local highway @ around 3 AM.
Old Apr 13, 2006 | 04:14 AM
  #44
Astronomer's Avatar
Astronomer
Originally Posted by als2052
The question should really be, "How fast has anyone safely driven a C6?
Two miles an hour as I enter my garage. :-)
Old Apr 13, 2006 | 06:22 AM
  #45
Turbooo2u's Avatar
Turbooo2u
How close to redline was this??
Old Apr 13, 2006 | 09:34 AM
  #46
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
173 on an German Autobahn with a little room left on my '05 Z51 MN6. It was very stable and I was able to change lanes without feeling light. My buddies '04 Z06 had the front fenders swell out due to the air pressure from the brake cooling ducts (I think) and his felt a little light on the front-end. I believe that it will get to 186 without a problem. Bill
Old Apr 13, 2006 | 09:55 AM
  #47
Irv's Avatar
Irv
Default Mach .855
I was looking at a picture of mine while flying in a 747.
Old Apr 13, 2006 | 11:15 AM
  #48
SpinMonster's Avatar
SpinMonster
I guess the HPtuners tab is wrong stating the speed limiter is set to 186. Maybe the ones that did better had a tune and moved it up.
Old Apr 13, 2006 | 11:22 AM
  #49
Zig's Avatar
Zig
From: stafford country, va. Avatar: Me on turn 3 @ Bristol (The World's Fastest Half-Mile)
hhmm.. good point... that's also why i was interested in how the results were obtained.
Old Apr 13, 2006 | 11:49 AM
  #50
BIGGGIE's Avatar
BIGGGIE
St. Jude Donor '05-'06-'07-'08
Mine was Removed with my Tune...all i remmber is seeing the 190 on the Heads up and i let off...
Old Apr 13, 2006 | 11:51 AM
  #51
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
152 on a bridge.
http://videos.streetfire.net/search/...421977993A.htm
picture is worth 1,000 words, but videos are priceless
Old Apr 13, 2006 | 12:37 PM
  #52
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
164 on the great roads of Texas
Old Apr 13, 2006 | 12:39 PM
  #53
C6 DVL's Avatar
C6 DVL
St. Jude Donor '08
I just came back from Vegas, the roads out there, you can do 120 all day long
Old Apr 13, 2006 | 01:15 PM
  #54
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
promod69camaro-
That's an interesting point, I can't give a positive answer but the few dyno runs I have seen show the A6 making less HP at the wheels than the MN6. Since they run under WOT, usually all the way to redline, the extra HP is going somewhere. Whether the TC is locked or not isn't the complete issue, what counts is HP delivered to the rear wheels.
Old Apr 14, 2006 | 02:28 PM
  #55
ricatthebeach's Avatar
ricatthebeach
Originally Posted by C6400hp
I'm not sure if it will do 186 or not. It will do 150 quite easily though. This of course was done on a private track.
of course
Old Apr 14, 2006 | 02:32 PM
  #56
ricatthebeach
I find this hard to believe. I've had my Z51 MN6 Vert to 155 in 5th and was tacking 5500.
Old Apr 14, 2006 | 02:33 PM
  #57
ricatthebeach
I've taken a cel phone call at 100 mph. No problem. Car feels glued to ground and tight at that speed
To How fast has anyone driven a C6?
Old Apr 14, 2006 | 02:39 PM
  #58
H20Vette's Avatar
H20Vette
Even when the convertor is locked there are still losses to mechanical friction inside the tranny. Automatic transmissions are known for having more internal losses than manual transmissions. If you want proof, look no further than your local dyno. The automatic will dyno lower.
Old Apr 14, 2006 | 03:17 PM
  #59
sallen619's Avatar
sallen619
Originally Posted by C6 DVL
152 on a bridge.
OUCH!!! Please turn it off next time!!!
Old Apr 14, 2006 | 04:15 PM
  #60
dbratten's Avatar
dbratten
Unless your car has had the rear gears changed to 4.00 or you're running a 23" tall tire 155 MPH is around 4700 RPM. Perhaps you were on the cell phone again?
