my 1st pass ever...
Old Apr 11, 2006 | 11:34 PM
vette-oholic's Avatar
vette-oholic
Default my 1st pass ever...
05 Z51 MN6
ET 112.86 @ 12.814 w/ 2.132 60'
RT = .368
this was at ATCO, temp around 55
i had a FULL tank of gas and rear tires are BALD
not sure if these things helped or not, but Im not too disappointed considering this was my 1st time ever racing a car
wow that was fun and i could see how it ould be ADDICTING.
unforutanately a c5z06 blew up there tonight... not sure the details.
jordan
Old Apr 11, 2006 | 11:38 PM
oobatz's Avatar
oobatz
Sweet!!!! That is great for your very first time and first run!
Old Apr 11, 2006 | 11:51 PM
BoilerRxC6's Avatar
BoilerRxC6
Get a few more passes under your belt and you'll be 12.2-12.4. And then you'll start shelling out a$$loads of cash to get to 11.2-11.4 and so on
Old Apr 12, 2006 | 07:01 AM
yell03's Avatar
yell03
CONGRATS on 12s your 1st time out!
Doing that in a MN6 is not an easy feat if you have never done it before.
The FULL tank of fuel hurt you by about 0.1 and 1mph, try to keep fuel in between 1/4 and 1/2. You probably had an extra 100#s in there.
Bald tires give you more contact patch, but less tread, so that is a wash.
Most Important:
Learn to get your 60' down to the 2.0 to 1.9 range, much harder with a manual tranny.
For every 0.1 you knock off your 60', your 1/4 et will driop by 0.2
So, if you cut a 2.03 60'. your time would have been a 12.61, and a 1.98 would have netted you a 12.51. Minus that extra 100#s of fuel and you will be running 12.41@113.86-114.x in no time.
Don't ever worry about your rt, the clocks don't start moving until the car does, you could sit there for 30 seconds, your rt will be a 30 seonds, but your time will still be a 12.51.
Congrats again,
Howard
Old Apr 12, 2006 | 08:24 AM
ArmySSG's Avatar
ArmySSG
or convert the vette into awd add another 200hp and hit a 1.6 60ft time, that should produce some nice numbers =oþ
Old Apr 12, 2006 | 08:31 AM
SHOOTER 49's Avatar
SHOOTER 49
And after modding and getting into the low 11's you may have guys saying a c6 blew up tonight.
Old Apr 12, 2006 | 11:14 AM
Fore58's Avatar
Fore58
You were just cruising with that 2.1 60ft. At least you know now that you have fast car. You have plenty left. Good job!
Old Apr 12, 2006 | 11:34 AM
oobatz's Avatar
oobatz
Curious, what RPM did you launch at? Also did you run with TCS and AH on/off in competitive mode???
Old Apr 12, 2006 | 11:38 AM
yell03's Avatar
yell03
Competetive mode is TC off/AH on in a less intrusive mode.
Howard
Old Apr 12, 2006 | 11:56 AM
vette-oholic
TC/AH OFF (pressed button for 6 seconds)
Tried to Launch around 3k
10k miles on car
Old Apr 12, 2006 | 12:49 PM
JELSIS's Avatar
JELSIS
Nice times for your first pass! With a few more passes you will definitely drop a few tenths off your time. It is addicting.
To my 1st pass ever...
