Thinking about bilstein or Z06 shocks....
Old Apr 12, 2006 | 01:19 PM
fstcrr54321's Avatar
fstcrr54321
Default Thinking about bilstein or Z06 shocks....
I'm contemplating getting Bilstien or ZO6 shocks.
Can anyone who have them already let me know how they affect handling and ride stiffness? Curretly have a Z51 C6
Also what was the total cost of this upgrade for you?
Thanks,
Jeff
Old Apr 12, 2006 | 02:06 PM
rfopt's Avatar
rfopt
I put the C6 Z06 shocks on my stock Z51. The handling improved a little. Overall control improved a little. Overall there is less of a soft feel and more of a controlled feel. The ride did not deteriorate much at all. Only noticable on bad roads. This is how the Z51 should have been tuned from the factory. I paid about $200 total for all four shocks.
Old Apr 12, 2006 | 04:16 PM
midnite902's Avatar
midnite902
I just put the LPE Konis on my car. Big difference!!! The car launchs much better now. It transtions from spin to hook with no hop in First gear on F1 Runflats. The ride is more supple than stock but is firmer and provides more control. Cornering has improved and so had traction coming out of corners.
These shocks come preset for the C6 from Lingenfelter. I went with the settings they came siwht but they are 3 way adjustable for both compression and rebound. On the Koni website are god instruction for tuningg the shock for autocrossing and roadracing.
Great shocks and a good price compared to Penske or comparable shocks
I had mine installed at 21st Century Musclecars in Carrolton Texas and authorized Lingenfelter installer.
Note: Marks left by the OEM shocks that had already began to leak.
Old Apr 12, 2006 | 08:17 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
If I were going to go to the trouble of replacing the shocks, I would go to aftermarket (Bilstein or Koni) as well.
Old Apr 12, 2006 | 08:39 PM
Zoli007's Avatar
Zoli007
Hey midnight how much did those Koni's run you?
Old Apr 12, 2006 | 09:17 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
C5 Z06 Bilstein? or does it matter? Also the Sports are stiffer than the HD's correct?
Old Apr 13, 2006 | 01:12 AM
Brabus2's Avatar
Brabus2
Midnite, those Konis look baddass!!! Sorry for the noob question, will adding the Konis affect my current (lowered) ride height? How long to install?? I'm been debating Bilstein or Koni, I have Bilstein Sports on my other cars and yet no experience with Konis...thanks for sharing the info!
Old Apr 13, 2006 | 02:41 PM
TTRotary's Avatar
TTRotary
Also, Midnite, can you tell us how easy / difficult it is to adjust rebound / compression. I read access was not ideal due to how the shocks mount on the C5/C6. Thanks
TommyV: Yes, Sports are the stiffer of the two. Also, the 04' C5 Z06 shocks and the C6 Z51 shock are essentially identical in valving and are the "improved and Nurburgring tuned" Sachs shock. Pre-2004 Z06 shocks are sloppy and no good. The '04+ stuff is better especially because they tightened up rebound, but the Bilsteins are still better. Bilstein is the master of good damper control in a reasonably priced shock.
Old Apr 13, 2006 | 05:09 PM
midnite902's Avatar
midnite902
The LPE Konis are 229 each from LPE About 1/3 the price of the Penskes.
Old Apr 13, 2006 | 06:44 PM
DJ50245's Avatar
DJ50245
2nd Gear
Bilstien's are great! Had them installed on my 92 Lexus SC with Eibach pro kit. The ride is so much better, can't go wrong.
Old Apr 13, 2006 | 08:05 PM
TommyV's Avatar
TommyV
I guess I worded my question wrong. Are all the Bilstein HD shocks for the C5 the same?
Old Apr 14, 2006 | 12:11 PM
TTRotary's Avatar
TTRotary
You want the Sports and, yes, they are the same shock. Bilstein has stated they consider the "C5 shock" fine for the C6 as well.
Old Apr 14, 2006 | 02:42 PM
sallen619's Avatar
sallen619
Bilsteins are the best thing I've done for my C6!
Old Apr 15, 2006 | 03:41 AM
SpinMonster's Avatar
SpinMonster
Z51 here with bilstein sports. Its a rough ride at times. I got the stiffer ones to get rid of wheel hop but it didnt help much. I would go for the HD's instead.
Old Apr 15, 2006 | 07:51 AM
midnite902's Avatar
midnite902
Will not impact lowering. John Page is installing on his slammed Z. I have always run Bilsteins on my cars but these seem a step up.
Old Apr 15, 2006 | 07:55 AM
midnite902's Avatar
midnite902
They are adjustable for both compression and rebound. Compression is adjustable on the car with a spanner, Rebound adjustment requires unbolting the shock and turning the shaft,
The come with the LPE setup for the C6 and I didn't need to adjust.
Old Apr 18, 2006 | 06:54 AM
AraiGP4's Avatar
AraiGP4
Thanks,
Jeff
I had the dealer install a set of Z06 shocks on my '05 C6 Z51 MN6 to improve rebound response at about 7,000 miles. Turn in feels crisper, rear end feels more planted, ride is more controlled, car feels more stable all around. An excellent mod with only a slight (and welcome) increase in ride stiffness. Cost about $600 installed at dealer, including alignment. Be sure they replace the mounting bolts when they replace the shocks, as they are one time use only bolts. Also, be sure to get a four wheel alignment at the same time.
I chose Z06 shocks instead of Bilsteins or Konis because they are specifically engineered for that chassis and I didn't want to change the front/rear balance. There were no changes to the sway bars or springs. A highly recommended mod for a daily driver, driven by an enthusiast. They take a few hundred miles to "break in" and a side benefit is much reduced front end bottoming. These are the shocks GM should have put on the Z51 in the first place.
To Thinking about bilstein or Z06 shocks....
Old Apr 18, 2006 | 08:22 AM
6 speed Sid's Avatar
6 speed Sid
AraiGP4, did you use the C-6, ZO6 shocks or the C-5, ZO6 shocks?
Old Apr 18, 2006 | 08:32 AM
sunsetZ51's Avatar
sunsetZ51
id go with the konis or billsteins
Old Apr 23, 2006 | 02:52 AM
AraiGP4's Avatar
AraiGP4
C6 Z06 shocks
