It is GM part #12497482 made by Mcgard. That's what the dealership ordered for me and installed.
I don't know what those other 2 numbers come up from mcgard unless part numbers change alot.
The GM wheel locks are indeed made by McGard, and the instructions make that clear. The problem is that if you want to buy a second set of locks with the same key (two cars, first set wore out, etc) then McGard will sell you a complete set with same key if you bought them under the McGard name, but if you bought them under the GM name then you have to order each lock as an individual part. That practically doubles the price. Just found this out a couple of weeks ago when I called McGard.
Also, the McGard instructions brag about how they are weight-matched to the ordinary nuts, but that's a lie. I weighed a lock and a regular nut, the lock is distinctly heavier. Fortunately they are so close to the axle that it has little effect, about equal to 1/2 of those little stick-on weights. If you really want to get precise, put the locks on directly opposite the valve stem, then cut a weight in half and stick it on near the valve stem.
