Driver Seat Removal
Old Apr 16, 2006 | 05:57 PM
Sleddriver's Avatar
Sleddriver
Default Driver Seat Removal
I would like to remove the driver's seat in my C6. How do you take the plastic covers off of the front frame mounts?
Also, does anyone else out there find the seat bottom of the C6 to be less padded/comfortable than the C5 was?
Thanks!
Old Apr 16, 2006 | 07:24 PM
autoxnut's Avatar
autoxnut
There is a plastic "rivet" in the vertical portion of the cover. Use a small tack puller to pry out the center about 1/2" and then the outer portion of the "rivet" can be pulled out of the metal. Then, slide the plastic cover forward while holding down on the base. Hope this helps.
Old Apr 16, 2006 | 09:58 PM
ZeusC6's Avatar
ZeusC6
Banned Scam/Spammer
You better stop there if you can't get them off!
Old Apr 16, 2006 | 11:32 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If your car's got 'em, better figure out how to disarm the side airbags!
Old Apr 17, 2006 | 12:16 AM
Sleddriver's Avatar
Sleddriver
Thanks; I'll give it a look tomorrow...
Old Apr 17, 2006 | 12:22 PM
Sleddriver's Avatar
Sleddriver
Okay, so my car's got side airbags. What do I do?
The purpose for my exercise is to see if I can add additional padding to the seat center. The padding seems thin relative to the C5 seats, and I wanted to punch it up a bit.
To Driver Seat Removal
