C6 Wheels on a C5
Old Apr 16, 2006 | 07:00 PM
RD in SD's Avatar
RD in SD
Default C6 Wheels on a C5
Will it work? I have brand new 2006 Z51 C6 Wheels and tires and I want to put them on a C5. Is it as simple as bolting them up?
Old Apr 21, 2006 | 04:42 PM
fat bob's Avatar
fat bob
RD,this is being discussed greatly on the Forum but it my opinion ,yes they will work. Of course, the sensors will absoutley not work and if you want TPS you will have to install the correct sensors for your year C-5. There have been posts that specifically say they will not work but I do not agree. I can supply you with the math, (comparsion of tire sizes, revs per mile, etc. if you need that info. I am not talking as an expert just giving you an opinion.
The overall dimensions (DIAMETER and CIRCUMFRENCE of the C-5 and C-6 are almost identical. I can give you the figures if it will help. I believe the offsets are close enough that when you caculate the section difference between the two it should work. I am in the process now of putting 18's all around from a C-5 on a C-6.
I don't want a disagreement with anyone who says they will not work. It is my opinion only. I suggest you "bolt them on " and try for yourself.
Bob
Old Apr 22, 2006 | 01:32 AM
shurite44's Avatar
shurite44
Wheel specs for the C5 and C6 and different offsets for your reference.
This spec data apply's to all C5 and C6's I believe.
5/120.65 mm bolt pattern, 70.5 mm CB, 12x1.5 Thread
Different sizes
C5 17x8.5 front 18x9.5 rear
C5 Z06 17x9.5 front and 18x10.5 rear
C6 18x8.5 front and 19x10 rear
C6 Z06 18x9.5 front 19x12 rear
These are all positive and in mm's
C5 front 58
C5 rear 65
Z06 front 54
Z06 rear 58
C6 front 56
C6 rear 79
C6 Z front 40
C6 Z rear 59
Old Apr 22, 2006 | 01:41 AM
icedancer's Avatar
icedancer
CI 6-7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09
A member of our club has C6 wheels on his C5, and the C5 is lowered.
He has had the wheels on for some time.
PM me a phone number and email address and I will have Jay give you a call, or at least an email.
Jay does not frequent this forum, to my knowledge.
Old Apr 22, 2006 | 09:57 AM
haljensen's Avatar
haljensen
Bolt pattern is no problem, front offset is no problem, brake clearance is no problem BUT the C6 rear offset puts the tire and wheel further inboard, should clear but try a test fit if possible.
Old Apr 22, 2006 | 11:12 AM
Pontiaker's Avatar
Pontiaker
Had my C6 wheels on my C5 since I brought the C6 home. They fit perfect, no rubbing no problems.
Matt
Old Apr 22, 2006 | 02:15 PM
shurite44's Avatar
shurite44
They look good Cucc! Surprisingly so. What size tire?
Old Apr 22, 2006 | 02:28 PM
Pontiaker's Avatar
Pontiaker
Just stock runflats. The rear is 285/35/19 and I dont remember what the front is? They are also almost the exact same outside diam as the stock size C5 wheels and tires. I weighed them too if you want to know what they weigh.
To C6 Wheels on a C5
