Please help ASAP
Old Apr 17, 2006 | 05:31 PM
1QWKSTI's Avatar
1QWKSTI
6th Gear
Default Please help ASAP
I am in the process of removing the bumper on a new Z06, Almost have it all off but I am have a problem in the area between the headlight and hood.Is there a hidden bolt?
Old Apr 17, 2006 | 08:47 PM
ffbor750's Avatar
ffbor750
no answer to question. have one of my own.
i take it you have a c6..does the bumper from the '06 z06 fit the c6
Old Apr 17, 2006 | 11:34 PM
LS1LT1's Avatar
LS1LT1
No, not without also changing to the Z06 front fenders as well.
Old Apr 18, 2006 | 09:48 AM
haljensen's Avatar
haljensen
On a C6 the procedure is; To remove the front facia (bumper cover) the shop manual says to remove the 5 inner fender fasteners, then 5 bolts under the griile opening, then 3 bolts in the upper bracket, then 4 nuts that hold the facia to the fenders, then 4 more bolts in the upper bracket. Don't forget to disconnect all the wiring.
Old Apr 18, 2006 | 12:03 PM
1QWKSTI's Avatar
1QWKSTI
6th Gear
Thanks I figured it out.
Old Apr 18, 2006 | 04:12 PM
serendipity's Avatar
serendipity
How quick is/was your STi?
Old Apr 18, 2006 | 04:36 PM
1QWKSTI's Avatar
1QWKSTI
6th Gear
Mid 12's as it sits withthe stock turbo, put down 330whp and 360wftlbs. Should be low 11's as soon as I put on the new turbo.
To Please help ASAP
