Heat Insulation for wires
Old Apr 21, 2006 | 10:32 AM
05_C6Z51's Avatar
05_C6Z51
Default Heat Insulation for wires
I want to wrap some things under the hood to protect against the heat the headers are giving off. I'm told the foil tape is not a good idea.
Does anyone know where I can buy the type of material that is around the o2 sensor wires? Are there other materials I can use? Please advise. Thank you.
Old Apr 21, 2006 | 11:05 AM
davidfarmer's Avatar
davidfarmer
Autozone/Advance sell little "booties" that slip over the spark plug wire ends, and could be used for other wires as well. It is basically header-wrap type material, but shaped just long/large enough to fit over the plug wire end.
You could also get a set of LS6 wires, as they had larger shields built into them.
Old Apr 21, 2006 | 01:22 PM
xs650's Avatar
xs650
If you have the space, most anything you can stick between the headers and whatever you are trying to protect will do the job as long as it can take the heat and doesn't touch the headers or whatever you are trying to protect.
Old Apr 21, 2006 | 01:46 PM
DSOMC6's Avatar
DSOMC6
Ceramic coat the headers Cuts down on the heat and no CEL for me with 600 miles so far.
Old Apr 21, 2006 | 02:30 PM
dbradley's Avatar
dbradley
Both Jeg's and Summit have bulk wire coverings just for this purpose.
Old Apr 21, 2006 | 03:26 PM
05_C6Z51's Avatar
05_C6Z51
Thanks, I'll see what I can find on their site.
To Heat Insulation for wires
