Question about Callaway Honker
Old Apr 24, 2006 | 10:32 PM
zorasdream's Avatar
zorasdream
Default Question about Callaway Honker
Hi guys It seems like the honker has the best feedback and I'm just about ready to order one but was wondering if it will change the sound of the car at all. Thanks Rob
Old Apr 24, 2006 | 10:59 PM
Jimspeed's Avatar
Jimspeed
it makes a whistle/sucking noise but nothing really.
Old Apr 24, 2006 | 11:03 PM
'06 Quicksilver Z06's Avatar
'06 Quicksilver Z06
It makes a very faint whistling/sucking sound. High pitched. Almost sounds like a belt chirp when you are in the gas pedal
Old Apr 25, 2006 | 06:26 AM
Fore58's Avatar
Fore58
Sounds like a small supercharger.
Old Apr 25, 2006 | 07:53 AM
zorasdream's Avatar
zorasdream
thanks guys sounds like nothing that will bother me
Old Apr 25, 2006 | 08:30 AM
DaBullish1's Avatar
DaBullish1
I agree, it whistles slightly. After getting my LG headers and Borla sport exhaust I can't hear it anymore... My stereo isn't loud enough either.
Old Apr 25, 2006 | 04:04 PM
BearCreekC6's Avatar
BearCreekC6
I bought the package from Callaway. Can't hear the whistle and the exhaust sounds great!!
Old Apr 25, 2006 | 04:22 PM
gorillavet's Avatar
gorillavet
If installed properly it should not whistle.
It will lower the tone of your exhaust slightly but the best change is a very smooth throttle response.
Old Apr 25, 2006 | 07:19 PM
'06 Quicksilver Z06
Why not? I think all aftermarket cold air intakes make more noise than stock.
I have gone over my install with a fine tooth comb and pride myself on being able to use a wrench. I cannot find anything wrong with my install.
Old Apr 25, 2006 | 08:01 PM
pennys58's Avatar
pennys58
SC CF Senior Member
St. Jude Donor '06-'07-'08
How long did the install take?? I was told 2.5 hours and $250.00...
Old Apr 25, 2006 | 08:15 PM
'06 Quicksilver Z06
Count on 3 hrs unless you have done one of them before. Getting the radiator shroud out is whats so time consuming.
First you have to mark it with tape for your cut. Then you have to remove it.
Once you get it finally removed you'll have to cut it, drill the holes for the rivets, and rivet the filter frame into it. Then reinstall it. May as well count on using new fasteners to secure it to the AC condenser, as you will likely destroy the factory ones getting that shroud out.
Old Apr 25, 2006 | 08:22 PM
RyanC7's Avatar
RyanC7
Oh bull Fing spit it won't wistle. You deaf? Is not procharger loud but it does whistle, so does a haltech, vortec and any other intake you can name except stock.
Old Apr 26, 2006 | 12:54 AM
chip4's Avatar
chip4
Mine whistles too, just before 3k rpm -with the windows down it is audible and can be easily mistaken by other cars as "forced induction" noise, usually happens to me during 1-3 gears (mn6)
Callaway's response:
http://forums.corvetteforum.com/show...light=callaway
Old Apr 27, 2006 | 05:34 PM
hookem79's Avatar
hookem79
I am considerind the Callaway cai. The fasteners that are mentioned above...where do you get replacements. Any hints on a step by step removal that will make this easier. Are the fasteners clips or for screws?
To Question about Callaway Honker
