Dyno numbers for a stock A6
Old Apr 27, 2006 | 11:59 AM
Jstyle's Avatar
Jstyle
Default Dyno numbers for a stock A6
What can I expect? Untuned, unmodified what can I hope to get out of it?
Old Apr 27, 2006 | 01:08 PM
LS1LT1's Avatar
LS1LT1
On a Dynojet, roughly 330-342 rear wheel horsepower (similar torque usually as well.).
The problem with dynoing the A6 is that there is no actual 1:1 gear ratio (the norm for dynoing) in the trans, it falls somewhere between 3rd and 4th so the end results will always be skewed slightly (some dyno it in 3rd, some in 4th) but you'll get a decent idea of where it is.
Old Apr 27, 2006 | 01:37 PM
suprkik's Avatar
suprkik
I averaged 325-330 rear wheel power on most of the c6 A6 dynos performed prior to tuning.
Ryan
Revxtreme.com
Your corvette performance specialist
Old Apr 27, 2006 | 01:52 PM
glennhl's Avatar
glennhl
Ryan
Revxtreme.com
And how much power/torque did you pick up with just a tune (not a tune and an exhaust, headers, or intake).
Thanks,
Glenn
Old Apr 27, 2006 | 02:11 PM
LS1LT1's Avatar
LS1LT1
Wow, a little lower than I'd thought, I've seen a few 337s/340s but I do think most are in the 330 range.
What gear did you pull them in, 3rd or 4th?
Old Apr 27, 2006 | 02:49 PM
little burt's Avatar
little burt
Default hp stock
500 miles on new 06 with auto paddle shift into 4 == 335.4, torque =339.7 burt
To Dyno numbers for a stock A6
