Brake light wires
Old Apr 27, 2006 | 11:41 PM
TommyV's Avatar
TommyV
St. Jude Donor '06-'07-'08-'09-'10-'11-'12, '16
Default Brake light wires
I received my Osram Joule LED assemblies today:
The adapter plug with wires is $5. Since these aren't designed for the C6's lens, (they may be one day) These are not "plug and play." Once you remove the OEM assembly, you have to rough up the edge around the opening of the lens and then epoxy the new one in. The gray seal around the base is rubber.
Two questions. I assume the C6's black wire is ground, Then there is a yellow and a brown. Anyone know which one is the brake light wire? And what would be a good epoxy to use? Thanks.
Here is the site from where I bought them. www.p-r-s.com They said that the assemblies are not on the site yet, but should be soon.
I will post pics and vid's once they're in. Probably not until Sunday.
Old Apr 28, 2006 | 03:38 PM
TommyV's Avatar
TommyV
No one knows which wire is the stop and which is the tail? Shopdog?
Old Apr 29, 2006 | 08:48 PM
Norske's Avatar
Norske
Old Apr 29, 2006 | 10:10 PM
Abomination's Avatar
Abomination
If your still waiting you could run to the store and grab a 10 dollar multimeter and check /shrug. I'm sure someone here has a shop manual though
To Brake light wires
