Now I Understand GM's Problems
I have just been informed by the Service Dept. of my dealer, who after "intense consultation with the T.A.C." that it is impossible to add an XM radio module to a Corvette if it was originally built without it. The reason given is that the Body Control Module (basically the computer that governs everything but the engine) is different for each type of Corvette. According to them, there are different BCMs for cars (1) with Nav; (2) without Nav; (3) with XM radio; (4) without XM radio; (5) with Nav and XM radio; (6) without Nav and XM radio, ad nauseum. With that many parts to manufacture and keep straight its no wonder that Delphi and GM are having money troubles. My preliminary and totally unofficial count is currently at 64 differently equipped Corvettes necessitating an equal number of different BCMs!!!
Of course, this could be
Anybody got any thoughts on how to do this? The car is 1SB equipped and the wiring harness is connected to the XM module which came from an '06 Corvette.
then, you might have to check out a new BCM. It would be interesting to find out if there are different part numbers for all the different iterations of the build. OR if the BCM can be flashed with the software for the XM radio.Personally, I'd contact the guys at XM tech support and ask about an aftermarket installation of the unit you have.
Good luck.
GM
No one seems to know if the base radio (1CD, MP3, RDS) is XM ready.
This radio is used in other GM cars, but I almost feel that the dealer will tell you it doesn't work as GM prefers to upsell a "package" that includes XM radio, Bose, Nav, etc.
Radio in my 1LT is a Siemens VDO Model GMX425. Research I've done states that if you have a "band button", "RDS", and an orange data wire in the harness, then the radio is a Class II Data Bus XM Ready head unit. The radio has an unused 12 pin black color data/ cd changer port on the rear upper right hand corner. The XM direct harness has a connector that fits this port along with a connector that fits the existing 24 pin port.
Part should arrive today, radio already out so I'll know if it works in a matter of minutes. If it does, I'll post the results and some pix.
IF YOU ARE INTERESTED, CONTACT ME AND I'LL DIG OUT THE PAPERWORK FOR YOU.
After I shut off the engine and restarted the car the radio then displayed only channels 1 & 2 which is reasonable as I had not activated the radio with XM itself. A quick phone call to them and that problem was corrected. The only thing I gained, but a great improvement, is the ability to turn off the radio when I shut the car down. I had inadvertantly left the Roady II in the console plugged into the cigarette lighter jack and run the battery down a couple of times.
Interesting to note however, is that according to the mechanic, the service writer, and, at least according to them, the GM Technical Assistance Center (T.A.C.) that you "cannot add" XM to car if it was not orginally built with it. They even went so far as to tell me that it was a different BCM for each type of car. . .not knowing that I would check to find there is one and only one BCM for a 2005 Corvette (part #H15216908).
Glad you got it working.
PM will follow
GM
That would be nice, but I think there would have to be a lot of programing done to get it to work right. That is if you could get someone to do it. Best bet Big Brother
would not be to happy about it. Remember GM said that the steering lock/reverse thing was a Fed thing.
I hope it can be done and that it works, cause I would get it done.
Ben, it must have been your lucky day! Was it your birthday and you didn't even know it???
Sounds like you found the answer
Agreed. My dealer still does not know anything about the MP3 upgrade for the radios in some of the early 05's. This has been available since December and even when I carried a copy of the TSB in to show them, they "didn't know". I bought the discs and did it myself in January. Now the discs are free if you can find someone to post them as a torrent.
anothercrisis
I have done this with limited success. If you go with an aftermarket unit, you will have a better situation if you have it directly wired to the head unit through an FM modulator.
The FM radio signal tends to come and go depending on what local stations are on the frequency you choose. This is avoided if you hard wire it.
