header coating
Old May 3, 2006 | 11:04 AM
cg-vette's Avatar
cg-vette
Default header coating
Just got a set of Kooks headers and was thinking about either doing ceramic or the hot-jet coating. First of all, is it worth spending the extra $$ on? I live in Florida and wanted to see if there were any places in the area that could do this.
Any suggestions or ideas would be helpful.
Old May 3, 2006 | 11:45 AM
megasport's Avatar
megasport
I think the ceramic coating is a must for the following reasons:
1) Significant reduction in the under the hood engine bay heat.
2) Higher exhaust gas velocity---heat stays in the exhaust gas improving hp and tq.
3) Enhances the life of the header by reducing corresion effects.
4) Helps heat the CAT and prevents CEL problems--assuming you
are using the after market CAT
Old May 3, 2006 | 12:23 PM
Tavarez's Avatar
Tavarez
I was curious about this too, would you coat the LG stainless steel ones aswell?
Old May 3, 2006 | 12:31 PM
Sinister Evil's Avatar
Sinister Evil
good question Tavarez.....i am wondering the same thing.
Old May 3, 2006 | 01:53 PM
crabman's Avatar
crabman
Yep, I would. Increases the life of your plug wires and such outside of the other advantages.
Old May 3, 2006 | 02:11 PM
Tavarez's Avatar
Tavarez
What are the performance advantages on the stainless steel if any?
Old May 3, 2006 | 02:20 PM
glennhl's Avatar
glennhl
No need to coat stainless steel, they do not rust and they already have a very low thermal conductivity. The underhood heat should be the same or less than mild steel headers that are coated. If you want the bling and even lower underhood temps, then coat them.
Old May 3, 2006 | 02:22 PM
Cookee's Avatar
Cookee
Also, it looks great! I personally hate some of the weld joints I have seen on some of the stainless headers!!!
Some will say it is not needed but then again many would also say 400HP is not needed. For me it has zilt to do with cost! I simply want the best looking set-up. If you then add the improvements referenced above it is a must for me.
Old May 3, 2006 | 03:04 PM
dollarbill's Avatar
dollarbill
St. Jude Donor '06-'07-'08-'09-'10-'11
Ok I agree with all that say that ceramic coatings lower temps under the hood. I have a set of coated hookers on a big block 69 Camaro and they look/function great. I got them from Hooker already coated.
Where does one go to get a set of Kooks coated as was in the original post at the beginning of this thread? I do not know. Also, I would like to know if a coating can be applied to a set of headers that have already been used?
Bill
Old May 3, 2006 | 04:43 PM
Abomination's Avatar
Abomination
TYBRNE has kooks, I just had them jet hot coat my headers and xpipe. Its a new option they have on their homepage. And yes you can coat used headers, just call jet hot.
Old May 3, 2006 | 09:42 PM
boosted_z06's Avatar
boosted_z06
Coating stainless steel can trap heat into welds and cause them to crack so there is no reason to coat them as they maintain heat better then mild steel.
Trapping heat can be a negative to the added heat to the O2s which then can report incorrectly and cause the VCM to incorrectly adjust the AFR.
If VCM is not tuned and trapped heat causes O2s and cats to be hotter also could cause the cat over temp (COT) circuit kick in sooner and dump excess gas in to cool the temps down at a loss of performance.
Being the headers are low and mostly under the car they are not adding that much heat to engine bay like the old manifolds used to do so coating SS does not buy anything since they would not rust like mild steel does.
Old May 4, 2006 | 01:10 AM
DSOMC6's Avatar
DSOMC6
Wrong my friend. Heat being trapped inside of header, welds, or anywhere else would only apply to a single coating applied to the outside of the header thus causing heat to become trapped inside with no way to disipate. LT's coated by any reputable coater will have ceramic applied to both the entire inside and entire outside which willnot allow them to trap heat. Thus heat absorbtion will be minimized because of the ceramic.
I have run a set of non coated and a set of ceramic coated LG LT's on two different c6's and I can say it was $$ well spent the second time around!
Looks awesome compared to raw stainless look.
Does not throw CEL compared to throwing a CEL within the first 10 minutes (without ceramic coating). This reason alone was worth the $$.
Lastly, actually improves performance which is proven by testing (I believe Jet-hot has the some results posted if I recall).
If you spend $1000+ on headers I would shell out the extra $$ for coating.
Old May 7, 2006 | 08:04 PM
nitrousvette's Avatar
nitrousvette
1st Gear
Yes you can ceramic coat the stainless headers also. It really helps out stainless headers, because stainless steel headers transfer more heat out into the engine compartment.
Old May 8, 2006 | 08:42 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
I believe so. Here's what I went with:
http://z06vette.com/forums/showthread.php?t=65536
You still need to take precautions with dressing O2 sensor wiring, etc., but it seems to help. 7000 miles later, they look as good as the day they were installed.
To header coating
