Brake sqeal
Old May 5, 2006 | 11:12 PM
bobodon's Avatar
bobodon
Cruising
Default Brake sqeal
My brakes were squealing and I thought it was the rear. (05' c-6 regular suspension). I deglazed rear and it kept doing it, so I put Morse Ceramic pads on rear. Still squealed. Found out it was front left. Deglazed front left with sandpaper and put the black GM squealing liquid on and I'm good now. 3 questions: 1. Am I ok with ceramics on rear and regular on front or should I put the Morse ceramics on the front as well? 2. Same breaking power with Morse Ceramics compared to stock? 3. If I leave the stock on the front, should I deglaze the other wheel and put the black liquid on as I am unsure if it changes the braking characteristics of the pad if black liquid is applied only to one front wheel? Thanks!
Old May 6, 2006 | 08:04 AM
EuroRod's Avatar
EuroRod
Yea, think I'd put the same pads at all 4 corners. I used "blue glue" on the backing plates of the pads on my Wilwood setup on the hybrid, and that reduced the squealing by 50%. Think the adhesive acts like a dampner to help control squealing. Good luck.
