To confirm, you want to go from Z51 rotors to base rotors?
If that is the case, you will simply need the base brackets and the rotors. I am changing to Z51 if you are interested in my base. Rotors have about 8000 miles.
Well, NAPA rotors are supposed to be $25. I'm sure stock base rotors are much more than that. What I really want to know is the part number for the bracket that locates the caliper so I can use the smaller (and much cheaper and easily found) rotors... I was hoping to not bug the FredBeans guys and to just order it via their website with the part number.
