I recently installed a B&B Bullet PRT.
I am looking to purchase a Supermaxx header system.
Will I be able to connect both of these or do I need to remove the PRT?
They will not fit together as-is. You would have to modify (cut/weld) the PRT section to mount it to the cats (if the PRT leaves enough room for them).
The Dynatech header package will be a direct bolt-on if you have the stock exhaust or an aftermark one that is just the rear section (doesn't include a center section).
