How to change bulb for signal light?
don't forget the bulb grease
I replaced my DRL/signal bulbs with white LED bulbs. The LED units draw very little current so you want damage the sockets by overheating. They should last forever. If you want to keep the amber lights, consider the LED "Switchbacks". When you go to the LED units you will get hyper flashing but installing a 6 ohm 50 watt load resistor in parallel with the LED bulbs will put them back flashing at the normal rate. Some prefer the faster flashing.
It's a little difficult to locate but there is a slot where you can feed the wires through under the headlight housing. I took a 4" long piece of 3/4" ID heater hose and slit it lengthwise and slipped it over the wire bundle that is above the fog light housing. I then used the nylon tie wraps to secure the load resistors to the heater hose. That way, if you do need to use the emerg flashers for an extended period of time, the load resistors heat won't damage the wire bundle. The LEDs can be installed in both directions. If they don't turn on at first, remove and turn 180 degrees and reinsert to get the polarity right. Plan on removing the front wheels to give you plenty of access to the lower opening.
Good info, thanks!
One more quick question:
Any problem with the resistors vs the plastic tie wraps?
Here's why I ask: The BCM activates the same circuit for DRLs as for turn signals or flashers. That's the "bright" side of the turn signal/parking light/DRL 3157 bulb socket. (on my '09 at least, other C6's similar?) This means in daylight w/ DRLs on the load resistors will be on continuously. Not harmfull to the resistors but they will generate some heat. Anyone know how much? Like a light bulb probably. I'm sure the heater hose will be OK but what about the plastic ties?
Good info, thanks!
Here's why I ask: The BCM activates the same circuit for DRLs as for turn signals or flashers. That's the "bright" side of the turn signal/parking light/DRL 3157 bulb socket. (on my '09 at least, other C6's similar?) This means in daylight w/ DRLs on the load resistors will be on continuously. Not harmfully to the resistors but they will generate some heat. Anyone know how much? Like a light bulb probably. I'm sure the heater hose will be OK but what about the plastic ties?
If you run with the DRL's on then the amber LED's will be on and the the circuit in the LED 'lamp' that turns off the white LED's will also be 'on'.
This switch part of the LED 'Switchback' system may fail prematurely and is why some manufacturers warn against running their LED's in DRL mode.
You are correct that if you run this way the load resistors will be on all the time and get very hot. You should use resistors with integral aluminum-finned heat sinks. You can also get an aluminum resistor mounting plate that adds additional cooling surface (check out V-LED's online).
You may want to consider mounting the load resistors in the engine compartment where they can get lots of air. You need to extend the cables and feed them through the existing holes/grommets.
Sorry to hijack the thread, but it is an old one.
