Larger tires
Old May 16, 2006 | 12:56 AM
'03blackonblack's Avatar
'03blackonblack
Default Larger tires
I would like to install larger than stock tires on stock rims. Is this possible? What would one size wider?, taller would be OK also.
Old May 16, 2006 | 07:55 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
One size wider will work both front & rear. 305 and wider on the back will require a wider rim. Go to TireRack.com for specifics
JT
