clearing codes with accessory buttons
Old May 19, 2006 | 10:49 AM
dtpracing's Avatar
dtpracing
Default clearing codes with accessory buttons
does anyone know if you can read codes on the CIC by using a combination of acc. buttons like you could on the C5?
ie hold options, then press fuel 4 times (on C5) takes you into manual diagnostics
Old May 19, 2006 | 11:46 AM
AFVETTE's Avatar
AFVETTE
Can't be done in the C6 like the C5. I bought a $70 error code reader to do what I could for FREE in the C5. That's progress.
Tom
PS: If you buy one make sure it works with the CAN Protocol
Old May 19, 2006 | 12:23 PM
dtpracing's Avatar
dtpracing
Thanks, wasn't sure if there were any tricks.
Old May 19, 2006 | 01:32 PM
fenderowner's Avatar
fenderowner
Equus 3030, available at Walmart for $69. Just bought one two days ago, and it works on the C6. HTH.
Old May 19, 2006 | 03:53 PM
99 torch red vette's Avatar
99 torch red vette
so it will read and Clear the codes?
Old May 19, 2006 | 04:26 PM
fenderowner
Yes. It's both OBDII and C.A.N. capable. You can check it out here http://www.iequus.com/item.asp?cid=7Had the check engine light come on with only 3600 miles on the car, thought it was gas cap related, but decided I could always use a code reader (my experience is that, if you are out of the warranty period, most places will charge you $50 or more just to read the codes for you...one of the more pronounced ripoffs in auto service these days, given the 9,000 reasons a check engine light can come on these days) so picked one up (also hopefully avoiding a trip to the dealer).
Read the code (P0400 I think..."slight leak detected in emissions system"), decided car was running just fine, so I erased the code and check engine light went off and has stayed off. Reader comes with all the generic codes listed in the user's manual, and comes with a CD (but I haven't had time to check it out) that MIGHT have vehicle unique codes in it (but you can get all the C6 codes off the web, just do a Google search for them or search the Forum - think somebody already posted them here). HTH.
Old May 19, 2006 | 11:00 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Yep.
http://forums.corvetteforum.com/show...post1554725224
Old May 19, 2006 | 11:08 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
good news, I'm off to walmart in the morning. maybe i can finally clear out the check gas cap and check engine light.
Old May 29, 2006 | 07:51 AM
AFVETTE's Avatar
AFVETTE
This is the one I bought and use. It does everything you need it to do.
http://www.diydiagnostics.com/
Tom
To clearing codes with accessory buttons
