Check Engine Light- PO451 code question
Old May 21, 2006 | 08:47 AM
Jackj42's Avatar
Jackj42
Default Check Engine Light- PO451 code question
I have had this code on three times in the two months I've had the car. It came on twice after I washed the car- it is the gas cap pressure code I think. I have erased it with my scanner tool and it stays off for a while...but I suspect it will go back on again. Has any one else had this problem and is there a permanent fix without taking it back to the dealer? No mods yet, BTW, but coming soon.
Thanks in advance.
Jack
Old May 21, 2006 | 11:03 AM
30YR W8T's Avatar
30YR W8T
Did you check your cap to make sure it has a good seal?
Old May 21, 2006 | 11:28 AM
VET4LES's Avatar
VET4LES
Code 0451 is Fuel tank pressure (FTP) Sensor performance ECM. If it was the cap the DIC would say check gas cap. I would take it to the dealer.
Old May 21, 2006 | 12:48 PM
Jackj42's Avatar
Jackj42
Thanks....Was trying to avoid the dealer.......I am assuming it isn't serious...
Old Jul 1, 2023 | 12:07 PM
flittlejr's Avatar
flittlejr
Thanks in advance.
Jack
Had same problem. Off for couple weeks, now almost daily. How can it be gas cap loose when you don't have gas cap?
Old Jul 1, 2023 | 12:32 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
What year is your car ???
To Check Engine Light- PO451 code question
