A6 Shifter broke again
Old May 27, 2006 | 04:41 PM
texvette2's Avatar
texvette2
Default A6 Shifter broke again
Posted before when it broke right after got the car. It binds and wont
move between the gears. Wont shut the lights off, locks the door and
have use the release to get out. Well they replaced the shifter at
150+- miles it has 500 now and broke again. Car is a month old.
They arent going to mess with it till they talk to GM which is
fine with me since dont feel comfortable driving the car anymore anyway.
Anyone else having this problem
Old May 27, 2006 | 05:03 PM
SHOOTER 49's Avatar
SHOOTER 49
Sorry--not yet and hope I don't.
Old May 27, 2006 | 05:08 PM
GasmanZR1's Avatar
GasmanZR1
Sorry to hear about your troubles. I just rolled 4000 miles on my vert with the A6 (bought on 11/03/05). I haven't had any problems with the shifter on mine. Good luck with getting yours fixed right!
PS- Sic em Bears!
Old May 27, 2006 | 05:26 PM
pitrider's Avatar
pitrider
4000 miles 2 months old no problems with my A6
Old May 27, 2006 | 10:15 PM
texvette2's Avatar
texvette2
Its going to be sometime before feeling comfortable driving that car.
If they can fix it. It might just be a lemon
Old May 28, 2006 | 07:18 PM
DSOMC6's Avatar
DSOMC6
4000+mi on the A6 and no problems. I do notice at wot on a couple of occasions I hit the paddle and it failed to shift up a gear. I'm still trying to determine if I failed to press hard enough on the paddle or the shift did not register electronically?
With the trouble you are having I would see if it falls under the lemon law. I hope you get it sorted out.
Old May 28, 2006 | 08:03 PM
LS WON's Avatar
LS WON
I have the A-4 from 2005 and when I put the shifter into park the DIC says "Shift to park" So I have to jiggle the shifter a bit and then the warning turns off.
Old May 28, 2006 | 08:26 PM
Vette_DD's Avatar
Vette_DD
Not an A6, but did have problems with the A4 shifter in my 05 about 2-3 months after I got it. Replacing it fixed the problem.
Old May 28, 2006 | 11:38 PM
texvette2's Avatar
texvette2
Mine gives no warning, the selector will not move, just binds up.
First time they had to pull it out of the garage onto a flat bed,
this last time was lucky it bound in drive and could drive it over
to the dealership. I think they have one more try by law till
the lemom takes effect. All said was they are not going to work
on it till talk to GM this time
but not only that going to start having rattles and no telling
what else since has been taken apart so many times. Right
now wish had kept the C5
Old May 29, 2006 | 12:39 AM
LS1LT1's Avatar
LS1LT1
No I haven't, had the car since January and it's been quite flawless...I'm surprised by this actually.
Old May 29, 2006 | 07:53 AM
BIG Dave's Avatar
BIG Dave
Originally Posted by gasman29
I just rolled 4000 miles on my vert with the A6 (bought on 11/03/06).
November 2006? That's not for another six months???
Old May 29, 2006 | 01:32 PM
GasmanZR1's Avatar
GasmanZR1
I'm back from the future......
J/K- I fixed it now.
Old May 31, 2006 | 12:00 PM
SoldSyclone's Avatar
SoldSyclone
8,700 miles on mine, the only problem the button rattle
Old May 31, 2006 | 06:13 PM
texvette2's Avatar
texvette2
Default Update
It seems GM is aware of the problem. They dont have a fix, not sure what it is. They put in another shifter (ordered when got my first, so had a replacement). All the tech told them to tell me was when putting in park is let it rest a bit before shutting off. That is going to be PIA. I did ask if had a time frame on a fix all said was maybe a month, maybe three. So guys it may be something that is just starting to crop up as too why were are not seeing any reports here. Sounds like wont be driving the car far from a Chevy dealership
Old May 31, 2006 | 06:20 PM
DSOMC6's Avatar
DSOMC6
I have shut the car off in drive (used to driving MN6) several times and then put it in park when it flashed on the DIC. Maybe that is a better solution?
Old Jun 1, 2006 | 12:58 AM
rhoward2's Avatar
rhoward2
My shifter locked up with 750 miles on it at four days old. Since it's been replaced I have had no problems other than button rattle. It now has 3400 miles on it, and I don't shut it down any special way. Maybe you just got two bad shifters in a row, and the third time will be the charm. Good luck with it.
Old Jun 1, 2006 | 02:04 AM
LS WON's Avatar
LS WON
Mine still does it I just put foot on brake and jiggle shift **** and DIC shuts off "shift to park".
Old Jun 1, 2006 | 04:05 PM
C-INRED's Avatar
C-INRED
St. Jude Donor '06
[QUOTE=DSOMC6]4000+mi on the A6 and no problems. I do notice at wot on a couple of occasions I hit the paddle and it failed to shift up a gear. QUOTE]
I've noticed that if I hit it too quickly it will sometimes fail to shift. I don't know if it's the duration of the press or how hard I press it.
Old Jun 2, 2006 | 10:30 PM
texvette2's Avatar
texvette2
Will see they seem to thinks its going to do it again. Hoping the
third is a charm but. In messing with it they got it go from park
to reverse, all gears without pressing the buttom. IT moved freely
so something has to be amiss in the drivetrain someplace
To A6 Shifter broke again
