HalltechSSM Installed and Baseline Dyno #
Here's my buddies Z06
I let him go in front of me to "warm up" the dyno. It's not my place to share his numbers so I won't but it gave me a pretty good idea of how accurate this dyno is. VERY accurate.
Last but not least I strapped on my 06 6-speed:
I'd like to mention two items:
1. My car just turned 1600 miles
2. I installed the B&B Rte 66 cat back exhaust
Some history. I and many of my buddies have used this dyno since 2001 when I did some before/after tests on my 99 6-speed coupe and my 03 Z06. Last Aug I wanted to see what a Blackwing added. Here's some numbers to put things in perspective:
My 6-speed 99 bone stock laid down 292 RWHP. After installing a Blackwing, Corsa Indy's and FLP LT headers it increased to 325 RWHP. Not bad for about a $3k investment.
My 03 Z laid down 354 RWHP bone stock at 4900 miles and 367 after a Blackwing, B&B PRT's and a Bassani X-pipe. So armed with this info and data I've collected from other new C6 owner reports I was hoping to see at least 35X with the B&B exhaust. I didn't. Here's the data:
This seems to explain why my 03 Z always felt faster. So today I installed the HalltechSSM air intake assenbly. The install was a breeze:
I'll put about 500 mils on the car and re-dyno it just to see what if any additional ponies I left in the barn.
I have another intake that caused surging and a few CEL which I removed and returned to the vendor. I decided on the Halltech based on conversations I had with Jim Hall and a few buddies that have installed the Stinger. So far no surging or CEL's.
I figure it'll take me about 3 weeks to roll up 500 miles so stay tuned for the next dyno test.
Tom
Your '03 Z06 will dyno about 3% higher than your C6 because it uses an 18 inch rear tire vs the 19 in tire on your C6.
I bought my 05 C6 Z51 with 2700 miles. It seemed much slower compared to my 02 Z06. But now I have 6000 miles and it feels like another 10-15hp. Although, no before and after dyno runs.
Tom
This car has the Halltech C6 Stinger ICAI System, headers, and cat backs.
The Outside Air Temperature was 78 degrees for most of the 30 mile LTF trim relearn drive, and interestingly, the Intake Air Temp was only 2 to 4 degrees hotter (80-82 degrees) than the outside air temp, even when stopping for stop lights.
I'll try to get a screen capture of this parameter for posting here.
"World Class Performance for your Corvette"
Intake Design and Engineering since 1999
Halltech Systems, LLC
423-915-6056
For service email:
orders@halltechsystems.com
www.halltechsystems.com
The second point I was trying to make was the fit and finish of the Halltech intake and the ease of installation. In my time behind the wheel so far (about 50 miles) the car (and throttle) really perked up. The throttle response seems sharper now.
Tom
Thanks. Could not have said it better. Tom
Todd
you should take your own advise...that person never say anything about "greater torque"...following is the exact quote incase you need some help."
Your '03 Z06 will dyno about 3% higher than your C6 because it uses an 18 inch rear tire vs the 19 in tire on your C6."
Thanks,
Glenn
