shifter problem
Old Jun 5, 2006 | 08:05 AM
fast eddie67's Avatar
fast eddie67
Navigator
Default shifter problem
I have a 2005 convertible with 3,000 miles and its been a while since I have posted. I seem to have had a problem with my manual trans. shifting into first gear from a stop, the linkeage is getting stuck and I need to down shift to second before it will go into first. Anyone experiencing this or is there a bulliten from GM about same????
Old Jun 5, 2006 | 08:30 AM
MyRedC6's Avatar
MyRedC6
I have the same issues on occasion. I thought that I had read about a TSB that if you had the problem more than 15% of the time GM would look at the issue. If not its not a major problem, at least to me.
Old Jun 5, 2006 | 08:35 AM
Dark Overlord's Avatar
Dark Overlord
I had this same issue.. But i think ive resolved it..
the dealer told me they couldnt find anything wrong...
sooo...
I took it to Corvettes of Houston - swapped out the tranny fluid and added Marvel Mystery Oil.. so far its like a perfect tranny!
hope this helps
Old Jun 5, 2006 | 01:09 PM
6 speed Sid's Avatar
6 speed Sid
No problem like that here so far.
Old Jun 5, 2006 | 01:49 PM
c6 corvette Z51's Avatar
c6 corvette Z51
sooo...
hope this helps
is that fluid better than royal purple
Old Jun 5, 2006 | 04:11 PM
gotagofast's Avatar
gotagofast
i have same prob on ocasion sometimes i cant even get it in first and have to start in second
Old Jun 5, 2006 | 05:14 PM
Korbo's Avatar
Korbo
I have the same issue. They will only honor the TSB if you fall within certain vin numbers. I think they replace the synchros in first gear. They would not fix mine. It is the most annoying "feature" of the car for me. I am pondering buying the parts and having the work done.
Old Jun 5, 2006 | 06:53 PM
Dark Overlord
i would suggest doing the "mystery oil" route first..... cost was 40 bucks for the tranny fluid swap and 5bucks for the marval mystery oil additive... so far two days later and zero issues shifting...
Corvettes Of HOuston did the work for me...
- and im not sure if the "royal purple" is any better...
Old Jun 5, 2006 | 06:54 PM
Dark Overlord
was the same here... had to shift into 2nd to get into first.....
Old Jun 5, 2006 | 08:18 PM
Jim_H's Avatar
Jim_H
Try double clutching when going to 1st.
Old Jun 5, 2006 | 08:20 PM
sallen619's Avatar
sallen619
same problem...
Old Jun 6, 2006 | 11:10 AM
AutoCutter's Avatar
AutoCutter
Have the problem, more so when I turn off the GAGS using the Predator. I find heel & toe downshifting 3th & 2nd helps regardless of whether GAGS is on or off. I tried Royal Purple which improved shifting in general, but it did little for the problem Frankly, I don't have enough faith with any of the dealers around here to have it fix'ed under the TBS.
To shifter problem
