DIY for lowering C6?
Old Jun 6, 2006 | 09:48 PM
TXVette06's Avatar
TXVette06
Default DIY for lowering C6?
I have talked to another C6 owner that lowered his Corvette by adjusting the stock coils with no cutting of the coils. Does anyone have a DIY procedure to lower the C6?
Old Jun 6, 2006 | 10:12 PM
Mr.Big's Avatar
Mr.Big
No coils on these my friend... To lower her all you need is a 10mm wrench or socket... At the end of each transverse spring there is a spring stop threaded through it from the bottom up... Put your wrench on that bad boy and turn counter clock wise till you get her where you like the stance.
To go any lower you must cut the rubber bumper off of the bottom of the spring stop that you just adjusted... to see how to do this check in the F.A.Q. section of the C6 forum...
Jeremy
Old Jun 6, 2006 | 10:21 PM
BEZ06's Avatar
BEZ06
TXVette
This thread discusses lowering it as far as it will go with the standard bolts (i.e., without cutting the bushings or replacing the bolts with the WCC replacement bolts):
Lowering Thread #1
This thread discusses swapping out the bolts or cutting the bushings on the stock bolts to get it lower:
Lowering Thread #2
I think that will give you about all the info you need!
Good luck. OBTW...don't forget to post pics when you're done!!!
Bob
Edited to add this additional info: In thread #2, post #19, I said that you must do a little minor disassembly of the rear suspension to cut the bolts. This is not necessarily so - If you scroll down to post #28 in that thread, Brianmargarita says that he was able to cut the rubber bushings down with a sawzall without undoing the suspension. I believe I've also seen a post that said you could undo some bolts at the top of the suspension rather than the bottom as I did. If you're gonna replace the bolts, you're gonna have to undo the suspension to get the old bolt out and the new one in.
Old Jun 7, 2006 | 10:55 AM
Low Rider's Avatar
Low Rider
I was able to cut my rear bushings by just removing the lower shock bolt and leaving the control arm bolts as is. It will take you less than an hour for the whole job....
Old Jun 7, 2006 | 03:40 PM
TXVette06's Avatar
TXVette06
Thanks for the help!
To DIY for lowering C6?
