plastic radiator shroud
Old Jun 6, 2006 | 09:58 PM
ogduncan's Avatar
ogduncan
Default plastic radiator shroud
Im installing a vararam intake and was wondering if we need to even keep the plastic radiator shroud.
Old Jun 6, 2006 | 10:31 PM
Zuntov's Avatar
Zuntov
GM calls the shroud a radiator baffle.
Upon removing and replacing the "baffle" a few times while doing CAI installations, I believe the baffle must enclose the engine compartment as much as possible.
Just looks like there could be a heck of a lot of uplift and turbulence under the hood at high speeds if the baffle wasn't in place.
Just my .02
Old Jun 8, 2006 | 10:40 PM
JohngC62005's Avatar
JohngC62005
Baffle must be in place. Can not run car without it. Bad idea.
Old Jun 9, 2006 | 12:07 AM
C6V3tt3's Avatar
C6V3tt3
I took mine out to let more in the my haltech stinger, i think it helps.
Old Jun 9, 2006 | 08:31 AM
CYA-Vett's Avatar
CYA-Vett
I think you can leave it out as well. I do not believe it does anything. Mine is just setting in there with no clips and it never moves or vibrates in the wind. I've only been up to 157 though, it might vibrate at higher speeds.
Old Jun 9, 2006 | 09:02 AM
Zuntov's Avatar
Zuntov
I can guarantee you there is a reason for the shroud or GM wouldn't spend the money for it. If they can save a penny, they will.
Old Jun 9, 2006 | 10:11 AM
haljensen's Avatar
haljensen
The shroud is a pretty important part of the cooling system, it forces the air to flow thru the radiator and coolers. Cutting it for a CAI only allows the aprx. 700CFM at full throttle to bypass the radiator, removing it would allow most of the air to bypass the radiator. Air will always flow to the area of the least resistance.
Old Jun 9, 2006 | 10:14 AM
Zuntov's Avatar
Zuntov
I was thinking about the cooling reasons as well.
I installed the Vararam snake charmer first and if you're off on your template alignment, (which is easy to do) it leaves a pretty good gap around the edges between the baffle and the filter assembly.
I eventually installed the Honker and there is not gap or seams at all around the filter to baffle seal.
Old Jun 9, 2006 | 10:23 AM
CYA-Vett's Avatar
CYA-Vett
Like the fuel rail covers?
I see your point but I don't necessarily buy it. There is a rather large fan behind the radiator for the function you speak of since no air flows through while sitting in traffic. Also while you sit in traffic the shroud would be counterproductive since it would retain heat. It might help a little to cool things down while driving, but the car will be fine without it.
I think it's in there for the same reason as the fuel rail covers..to make everything look pretty.
Old Jun 9, 2006 | 11:32 AM
haljensen's Avatar
haljensen
With the shroud in place I'm covered if a fan fails, all I have to do is keep the car moving to get air flow thru the radiator. Without the shroud a fan failure will cook your engine. The shroud is there to direct the incoming airflow to the radiator, the fan (and fan shroud ) is there to supply airflow out of the radiator. They both need to be working.
To plastic radiator shroud
