Seat doesn't move into driver position?
About 50% of the time now, when I get in and hit Start, the steering wheel will telescope but the seat will not slide forward to Driver 1 position. I can hit the Driver 1 button on the door all day and nothing. But, if I then move the seat with the adjustment switch, a little, and THEN hit the 1 button, it'll go the rest of the way.
I haven't really remembered a problem the other way (i.e. seat not sliding back to Easy Exit when I shut down and open the door)
What's this, then?
What's this, then?
In day while it was holding me hostage ( I couldn't reach the pedals well enoug tho drive) I reched under the seat and mover the wiring harness with my hand and....ureeka.....everything worked again.
took the car to the dealer and he found a bad connector in the seat wiring harness.
You might want to check it out.
Pat
And make sure that you're using fob #1 for the #1 memory buttons.
Also make sure that you haven't inadvertently programmed the exit button to a seat position, or visa versa. I've done that one!
Pat
