Problems with 2005 A/C?
Old Jun 15, 2006 | 09:40 PM
Steve Lutfy's Avatar
Steve Lutfy
Default Problems with 2005 A/C?
I have two intermittent problems. The first is that the A/C operates as normal, but the display does not illuminate until about 2 - 3 minutes after it has been running. During the "blackout", none of the other controls operate (none of buttons below the read-out, either driver or passenger temp control, etc). When the read-out finally illuminates, the system works fine. I have to assume that the A/C system is running at the last setting, since it IS blowing out cold.
My second problem is similar to the above, however, in this problem, nothing works. No A/C, no air, no nothing.
Has anyone experienced a similar problem? If so, what was done to correct the issue. Again, these 2 issues do not occur all the time.
