I just ordered my Procharger
Old Jun 16, 2006 | 06:04 PM
schilitj's Avatar
schilitj
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14
Default I just ordered my Procharger
Here's what I ordered:
Procharger D-1SC
60 lb injectors
Kenny Bell fuel pump booster
Injector extenders
Gauge frame and gauges (boost, fuel pressure)
Additional work:
New Output Shaft
Shift Point
This will be added to my existing setup:
AFR 225 Heads
Cam 224 230 581/592 114 LSA
Underdrive Pulley
Corsa Sports
Dynatech Supermaxx Headers
B&M Sport Shifter
Halltech Stinger w/CAI
160 Degree Thermostat
Tuned
that current produce the following numbers:
HORSEPOWER
TO THE CRANK = 521 TO THE RW = 443.1
TORQUE
TO THE CRANK = 470 TO THE RW = 399.8
I have a 05 C6 Z51, MN6
Everything should be in in about 3 weeks, then the install, tune/dyno. Jeremy Preston will take it down the track for me to see what it will do. Numbers will be posted.
Old Jun 16, 2006 | 06:17 PM
Schmo's Avatar
Schmo
Holy triple posts, batman!
Congrats, can't wait to see the numbers.
Old Jun 16, 2006 | 06:35 PM
bunk22's Avatar
bunk22
Will the stock C6 brakes be up to the task of this coming hp? Your car will be a monster.
Old Jun 16, 2006 | 06:52 PM
Miaugi's Avatar
Miaugi
Musta hit the boost buton!
midnite902's Avatar
midnite902
Add a blower cam to your list it makes a big difference.
Old Jun 16, 2006 | 07:09 PM
hamad115's Avatar
hamad115
Procharger D-1SC
60 lb injectors
Injector extenders
Additional work:
New Output Shaft
Shift Point
AFR 225 Heads
Underdrive Pulley
Corsa Sports
B&M Sport Shifter
Tuned
HORSEPOWER
TORQUE
Everything should be in in about 3 weeks, then the install, tune/dyno. Jeremy Perston will take it down the track for me to see what it will do. Numbers will be posted.
The AFR 225 Heads are too high for the D1 as long as it is high comp and i think you should lower the comp
Old Jun 16, 2006 | 07:40 PM
KillerVette's Avatar
KillerVette
yeah, i would be careful....what is your compression ratio now??
Old Jun 16, 2006 | 08:48 PM
vertC6's Avatar
vertC6
Exactly you want to drop compression, not increase it.
But your cam is perfect for a blower, high on the exhaust lift and duration.
Old Jun 16, 2006 | 08:52 PM
schilitj's Avatar
schilitj
Andy at A & A milled the heads and the comp is now 10.6:1. spoke with him before selecting the Procharger and he said I would be OK.
Old Jun 16, 2006 | 08:53 PM
schilitj's Avatar
schilitj
Sorry about the multiple posts, not exactly sure how it happened. I asked one of the moderators to close out the duplicates. :o
Old Jun 16, 2006 | 08:54 PM
PaBlueCoupe's Avatar
PaBlueCoupe
St. Jude Donor '06-'07-'09
Was that nitrous or nitrous oxide ( )
Old Jun 16, 2006 | 09:02 PM
schilitj's Avatar
schilitj
PaBlueCoupe & KillerVette
I'm originally from the Burg. Born and raised over the steel mills in Oakland. Moved to Mt. Lebanon for high school. Did my undergraduate work at Cal State in Cal. Pa, Masters at Penn State then went to Ohio (OSU) for my PhD.
Big Ben needs to have his head examined, that is after it heals
Jeff
Old Jun 16, 2006 | 09:04 PM
saplumr's Avatar
saplumr
Just go back and delete 'em.
Old Jun 16, 2006 | 09:07 PM
schilitj's Avatar
schilitj
I looked and did not see the "delete" option. Where is it?
Old Jun 16, 2006 | 09:12 PM
saplumr's Avatar
saplumr
It's on the edit bar. By the way, I checked today into upgrading from P1 to D1 and was told by my tuner I would not want to go above 580 RWHP to keep from blowing piston tops. I am going to upgrade blower and block in the winter. Did your tuner mention anything like that?
Old Jun 16, 2006 | 11:14 PM
Brabus2's Avatar
Brabus2
GM "powder rods" are a weak link for the radical boosted motors, good choice on upgrading the block or at least the proper components!
Old Jun 16, 2006 | 11:46 PM
schilitj's Avatar
schilitj
I upgraded the rods when I did the heads/cam. Use APR (?).
To I just ordered my Procharger
Old Jun 17, 2006 | 12:47 AM
Brabus2's Avatar
Brabus2
I'm refering to connecting rods, maybe you mean ARP rod bolts or head studs.
I betcha you'll be counting those days til installation...
Old Jun 17, 2006 | 02:55 AM
Schmo's Avatar
Schmo
Don't apologize... just having some fun. Can't wait to hear about your results. GOod luck with it!
Old Jun 17, 2006 | 02:25 PM
schilitj's Avatar
schilitj
The timeline looks like the 3rd week in July. The plan is to have the Procharger installed on 7/19-20 and have it tuned by Mike Norris on 7/21. Look for results then.
By Michael S. Palmer | 2026-06-03 11:00:24
